2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build system problem
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 16 Nov 2005 13:04:10 -0600
Ralph Lange wrote:
The two -Wl options (compiled-in locations for shared libraries) are correct: One location is the generic location, where the EPICS Base will be installed. The other is the local directory, i.e. the location of the Base that I'm currently linking against. This makes sure that the libraries are found on the development machine as well as on the runtime system (where the Base will be installed at the generic location).
Shouldn't your 'generic' path be pointing to an empty or non-existent directory though when you're compiling? You should change that path to /opt/epics/R3.14.8/support/base/3-14-8-0 or similar, so it will never try to link against old libraries. The -L option *should* be pointing to your local build tree since that gets used at compile time, but at runtime you also want it to search the install location.
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
Re: Build system problem Ralph Lange
mrkSoftTest doesn't compile Ralph Lange
Re: mrkSoftTest doesn't compile Marty Kraimer
Build system problem (was: mrkSoftTest doesn't compile) Ralph Lange
Prev: RE: R3.14.8 Status/logClient patch Jeff Hill
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build system problem (was: mrkSoftTest doesn't compile) Ralph Lange
Next: Re: Build system problem Ralph Lange
