Subject: |
Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] |
Ralph Lange <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 16 Nov 2005 17:20:13 +0100 |
Marty Kraimer wrote:
I found the cause of the crash.
The problem was calling epicsThreadSetPriority from a thread not
created via epicsThreadCreate.
I committed the change and a change to epicsThreadTest.cpp to test
epicsThreadSetPriority.
When I run epicsMessageQueueTestHost on solaris it never terminates
but does do everthing it should???
Is this the same issue that I reported on Nov 11th for Linux-x86? (See
attachment.)
Ralph
--- Begin Message ---
Subject: |
3.14.8@Linux: epicsMaxThreadsHost does not return |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Tue, 08 Nov 2005 13:13:44 +0100 |
On my Linux (Debian 3.1; gcc 3.3.5) box:
epicsMaxThreadsHost does not return properly. In most cases it runs
almost complete
aragon: .../base/3-14-X > bin/linux-x86/epicsMaxThreadsHost
stackSize 131072
100
200
300
400
500
600
700
800
900
1000
1100
1200
1300
1400
1500
number threads 1533
pthread_create error Resource temporarily unavailable
main terminating
then hangs at this point, probably in a system call (doesn't
recognize control chars, has to be killed explicitly with -9).
In other cases, the outputs stops before the "number threads"
line with the same behaviour.
In the hanging state, 'ps' shows zillions of threads, which I would
consider normal during that test.
I'm aware that this could be rather a Linux configuration problem than
really related (or even caused) by the test from base. Nevertheless:
Any hint about where I should look further?
Ralph
--- End Message ---
- Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Marty Kraimer
RE: dbEvent.c line 665 Jeff Hill
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
