Subject: |
Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] |
Marty Kraimer <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 16 Nov 2005 11:21:17 -0600 |
Ralph Lange wrote:
Marty Kraimer wrote:
I found the cause of the crash.
The problem was calling epicsThreadSetPriority from a thread not
created via epicsThreadCreate.
I committed the change and a change to epicsThreadTest.cpp to test
epicsThreadSetPriority.
When I run epicsMessageQueueTestHost on solaris it never terminates
but does do everthing it should???
Is this the same issue that I reported on Nov 11th for Linux-x86? (See
attachment.)
No. It was the issue Earnest raised.
For the problem shown below, I am not sure we can guarantee a fix. The
test keeps creating threads until it fails. At this point it is not
clear what state the underlying operating system is in.
Marty
Ralph
Subject:
3.14.8@Linux: epicsMaxThreadsHost does not return
Ralph Lange <[email protected]>
Date:
Tue, 08 Nov 2005 13:13:44 +0100
To:
EPICS Core Talk <[email protected]>
To:
On my Linux (Debian 3.1; gcc 3.3.5) box:
epicsMaxThreadsHost does not return properly. In most cases it runs
almost complete
aragon: .../base/3-14-X > bin/linux-x86/epicsMaxThreadsHost
stackSize 131072
100
200
300
400
500
600
700
800
900
1000
1100
1200
1300
1400
1500
number threads 1533
pthread_create error Resource temporarily unavailable
main terminating
then hangs at this point, probably in a system call (doesn't recognize
control chars, has to be killed explicitly with -9).
In other cases, the outputs stops /before/ the "number threads" line
with the same behaviour.
In the hanging state, 'ps' shows zillions of threads, which I would
consider normal during that test.
I'm aware that this could be rather a Linux configuration problem than
really related (or even caused) by the test from base. Nevertheless:
Any hint about where I should look further?
Ralph
- Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Marty Kraimer
- Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Ralph Lange
Re: dbEvent.c line 665 Marty Kraimer
<2005>
2025
2026
Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Ernest L. Williams Jr.
<2005>
2025
2026
