2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsAtExit
To: [email protected]
Date: Thu, 17 Nov 2005 07:28:44 -0600
Let me try to give an executive summary of epicsExit issues for 3.14
epicsExit is required and solves at least the following problems:
1) in vxWorks
   a)  Is an OSI replacement for rebootHookAdd
b) With patches to the board support package, the epicsAtExit handlers can be called BEFORE any rebootHook handlers. This will allow RSRV servers to
        terminate their connections.
2) On all systems it allows iocLog to terminate cleanly
3) On Windows and labViews????
4) It should be safe on all systems for RSRV to terminate it's connections.
It is not safe to have dbCaTask terminate and call ca_context_destroy.
Similarly just having arbitrary parts of iocCore cleaning up can cause crashes.
I am changing dbCa.c as follows:
diff -r1.67.2.5 dbCa.c
946c946,954
<     ca_context_destroy();
> /* This is not sufficient to clean up dbCa connections.
> *  The following should be done:
> *  1) All device support that uses dbCa should clean up
> *     This means that all channels should be deleted
> *     dbCa should check that this has been done
> *  2) dbCa should do the following:
> *     a) check that all channels have been deleted.
> *     b) call ca_context_destroy();
Any comments?
Marty
RE: dbEvent.c line 665 Jeff Hill
epicsAtExit Marty Kraimer
Re: epicsAtExit Andrew Johnson
Re: epicsAtExit Kay-Uwe Kasemir
Prev: Re: R3.14.8 Status/logClient patch Marty Kraimer
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsAtExit Kay-Uwe Kasemir
Next: Re: dbEvent.c line 665 Marty Kraimer
