2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrkSoftTest doesn't compile
To: Ralph Lange <[email protected]>
Cc: Janet Anderson <[email protected]>, EPICS Core Talk <[email protected]>
Date: Thu, 17 Nov 2005 09:17:56 -0600
Hi Ralph,
Ralph Lange wrote:
Is it illegal to use two compiled-in paths? From first glance I wouldn't see why. Does the build system rely on just one path being defined? If so: Is that limitation justified?
There is no problem having more than one path defined (it will just look through them one after the other until it finds the .so file), but you must ensure that it will never find a different version of the libraries at runtime than it saw at compile time, as I think I wrote yesterday - your 'final install' path should be pointing to an empty or non-existent directory until that version of base has been installed. You might also want to adjust the search order so it looks in the local build first by changing the order of the items in your mrkSoftTest's configure/RELEASE file; shared library searches should occur in the same order as the lines in that file.
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
Re: mrkSoftTest doesn't compile Ralph Lange
Prev: Re: R3.14.8 Status/logClient patch Marty Kraimer
Next: Re: mrkSoftTest doesn't compile Ralph Lange
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrkSoftTest doesn't compile Ralph Lange
