2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status/logClient patch
To: [email protected]
Date: Thu, 17 Nov 2005 09:14:15 -0600
I tested on linux, solaris, and vxWorks and all were OK.
Should I commit the changes?
Marty
Benjamin Franksen wrote:
I attached the latest and greatest version of the logClient library. No global variables, separate thread for each client. Shutdown (via epicsAtExit) was already implemented. I made some slight changes that should make shutdown a bit more robust, but kept the rest as it is.
Compiled under HP-UX and Linux for HP-UX, Linux (both tested, if only the standard ioc log) and VxWorks (not yet tested, will do tomorrow).
Docs not yet done; coming soon.
Jeff,
Could you plese elaborate what you meant with shutdown for read or write end of socket? I can't see how to do more than call epicsSocketDestroy.
Ben
RE: R3.14.8 Status/logClient patch Jeff Hill
Re: R3.14.8 Status/logClient patch Benjamin Franksen
Re: R3.14.8 Status/logClient patch Marty Kraimer
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: Re: mrkSoftTest doesn't compile Andrew Johnson
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: R3.14.8 Status/logClient patch Jeff Hill
