2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue"
To: EPICS Core Talk <[email protected]>
Date: Mon, 21 Nov 2005 09:11:43 -0600
Does it still happen with the latest committs to posix/osdThread.c?
Does this happen whenever you exit or only at random?
Marty
Ernest L. Williams Jr. wrote:
Another issue, when running the example softIOC under linux-x86_64
with:
USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
The following happens only when run as root and only when exit or
<CTRL>-C is used to exit the softIOC:
cd /ade/epics/iocTop/R3.14.8/testLinux64/iocBoot/iocamd64
iocInit()
Starting iocInit
###  EPICS IOC CORE built on Nov 17 2005
###  EPICS R3.14.7 $$Name: R3-14-2_branch $$ $$Date: 2004/12/06 22:31:52
iocInit: All initialization complete
## Start any sequence programs
#seq sncExample,"user=williamsHost"
epics> exit
epicsThread: Unknown C++ exception in thread "timerQueue" at Thu Nov 17
2005 21:37:19.751377000
Segmentation fault (core dumped)
[root@dragon iocamd64]#
Let's see what the backtrace yields:
(gdb) bt
#0  0x0000003892ab0faa in __gnu_cxx::__verbose_terminate_handler ()
from /usr/lib64/libstdc++.so.6
#1  0x0000003892aaf076 in __cxa_call_unexpected ()
#2  0x0000003892aaf0a3 in std::terminate () from /usr/lib64/libstdc
++.so.6
#3  0x0000003892aaf0b6 in std::terminate () from /usr/lib64/libstdc
++.so.6
#4  0x0000003892aaf0d3 in std::unexpected () from /usr/lib64/libstdc
++.so.6
#5  0x0000002a964b4663 in epicsThreadCallEntryPoint (pPvt=Variable
"pPvt" is not available.
) at ../../../src/libCom/osi/epicsThread.cpp:96
#6  0x0000002a964b9410 in start_routine (arg=Variable "arg" is not
available.
) at ../../../src/libCom/osi/os/posix/osdThread.c:316
#7  0x00000038908060aa in start_thread ()
from /lib64/tls/libpthread.so.0
#8  0x000000388fbc5b43 in clone () from /lib64/tls/libc.so.6
#9  0x0000000000000000 in ?? ()
(gdb)
Ernest
Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
Prev: Re: epicsThreadSetPriority called by non epics thread Marty Kraimer
Next: Re: priorities Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
Next: Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Ernest L. Williams Jr.
