2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: priorities
To: [email protected]
Date: Mon, 21 Nov 2005 09:29:25 -0600
Jeff Hill wrote:
Pursuing this a bit further, I notice, using epicsThreadShowAll, that the
OSI => OSD priority mapping maybe isn't working on POSIX (the OSSPRI column
is always zero)?
Again, this is building with USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES.
Two "features" of priority scheduling on linux.
1) On linux you must be running as root in order to be able to set SCHED_FIFO. The code is written to silently revert to non-priority scheduling if EPERM is returned. 2) Older versions of linux (perhaps all 2.4 versions without special patches) do not seem to support priority scheduling. The implementations seem to just silently ignore the priority scheduling requests even though _POSIX_THREAD_PRIORITY_SCHEDULING is defined.
This it seems that the only way to know if priority scheduling is being used is to run epicsThreadShowAll and see if the OSS prioritys have non zero values.
Note that solaris shows non-zero values WITHOUT being root. When I run top, I notice that the LWP has higher values than other processes. I do not know how solaris is managing the priorities.
Marty
Re: priorities Eric Norum
RE: priorities Jeff Hill
Prev: Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Marty Kraimer
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: Re: priorities Eric Norum
