2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status/logClient patch
To: [email protected]
Date: Mon, 21 Nov 2005 16:29:25 +0100
On Sunday 20 November 2005 13:42, Benjamin Franksen wrote:
> I have removed my bogus 'fix' for HP-UX from logClient.c. The file is
> attached. I hope this is the end of (this part of) the story, for
> 3.14.8 at least.
...and here is a (plain text) draft of Section 19.15 for the Deveoper's
Guide.
Cheers,
Ben
19.15 logClient
Together with the program iocLogServer this provides generic support for logging
text messages (from an IOC) to a file (on a host).
A /log client/ runs on the IOC and accepts string messages and forwards them over
a TCP connection to its designated log server (normally running on a host
machine).
A /log server/ accepts connections from multiple clients and writes the messages
it receives into a rotating file. A log server program ('iocLogServer') is also
part of EPICS base.
Configuration of the iocLogServer, as well as the standard iocLogClient that
internally uses this library, are described in Chapter 10.7 "iocLog".
The header file logClient.h exports the following types and routines:
typedef void *logClientId;
    An abstract data type, representing a log client.
logClientId logClientCreate (
    struct in_addr server_addr, unsigned short server_port);
    Create a new log client. Will block the calling task for a maximum of 2
    seconds trying to connect to a server with the given ip address and port. If a
    connection cannot be established, an error message is printed on the console,
    but the log client will keep trying to connect in the background. This is done
    by a background task, that will also periodically (every 5 seconds) flush
    pending messages out to the server.
void logClientSend (logClientId id, const char *message);
    Send teh given message to the given log client. Messages are not immediately
    sent to the log server. Instead they are sent whenever the cache overflows, or
    logClientFlush() is called.
void logClientFlush (logClientId id);
    Immediately send all outstanding messages to the server.
void logClientShow (logClientId id, unsigned level);
    Print information about the log clients internal state to stdout.
For backward compatibility with older versions of the logClient library, the
header file also includes iocLog.h, which exports the definitions for the standard
iocLogClient for error logging. See Chapter 10.7.2.
Also for backward compatibility, the following deprecated routines are exported.
logClientId logClientInit (void);
    Create a log client that uses the standard ioc log client environment
    variables (EPICS_IOC_LOG_INET and EPICS_IOC_LOG_PORT) as input to
    logClientCreate and also registers the log client with the errlog task using
    errlogAddListener.
void logClientSendMessage (logClientId id, const char *message);
    Check the global variable iocLogDisable before calling logClientSend.
RE: R3.14.8 Status/logClient patch Jeff Hill
Re: R3.14.8 Status/logClient patch Benjamin Franksen
Prev: Re: priorities Marty Kraimer
Next: Re: priorities Eric Norum
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: RE: R3.14.8 Status/logClient patch Jeff Hill
