2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: priorities
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Mon, 21 Nov 2005 09:41:42 -0600
On Nov 21, 2005, at 9:29 AM, Marty Kraimer wrote:
Jeff Hill wrote:
Pursuing this a bit further, I notice, using epicsThreadShowAll, that the
OSI => OSD priority mapping maybe isn't working on POSIX (the OSSPRI column
is always zero)?
Again, this is building with USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES.
Two "features" of priority scheduling on linux.
1) On linux you must be running as root in order to be able to set SCHED_FIFO.
 The code is written to silently revert to non-priority scheduling if EPERM is returned.
2) Older versions of linux (perhaps all 2.4 versions without special patches) do not seem to support priority scheduling. The implementations seem to just silently ignore the priority scheduling requests even though _POSIX_THREAD_PRIORITY_SCHEDULING is defined.
This it seems that the only way to know if priority scheduling is being used is to run  epicsThreadShowAll and see if the OSS prioritys have non zero values.
There should probably be tests added to src/libCom/test/epicsThreadTest.cpp to check for (a) non-zero OSS priorities and (b) whether or not the priority scheduling is strict.  The epicsMessageQueue test produces different results with strict and non-strict ('suggestive'??) priority schedulers.   A similar set of code would be useful in epicsThreadTest.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: priorities Marty Kraimer
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: reacting to CA server availability Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: priorities Marty Kraimer
Next: RE: priorities Jeff Hill
