On Friday 18 November 2005 17:37, Jeff Hill wrote:
> > Note: the text in this message corresponds to errno=EINPROGRESS,
> > whereas the reported errno is 0.
> I am starting to guess that maybe the HPUX build does not have its
> multi-threaded execution compiler options turned on for the C
> compiler. In particular, you need the one that makes errno a thread
> private variable. For HPUX we have "#define SOCKERRNO errno". Usually
> the thread safe errno compiler options causes something like "#define
> errno getErrno()" to be defined in one of the operating system header
> files.
> I had a look at this site (which appears to apply to both the C and
> c++ compliers):
> http://docs.hp.com/en/1559/options.htm
> I think you need to add -mt here
> CONFORM_CFLAGS_ANSI = -Aa -mt
> CONFORM_CFLAGS_STRICT = -Aa -mt
> CONFORM_CFLAGS_TRAD = -Ac -mt
Bingo! That fixes it. Many thanks for your help.
Janet,
these flags should be added in
base/configure/os/CONFIG.hpux-parisc.hpux-parisc.
Marty,
I have removed my bogus 'fix' for HP-UX from logClient.c. The file is
attached. I hope this is the end of (this part of) the story, for
3.14.8 at least.
Ben
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* logClient.c,v 1.25.2.6 2004/10/07 13:37:34 mrk Exp */
* Author: Jeffrey O. Hill
* Date: 080791
* ANSI C
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#define epicsExportSharedSymbols
#include "dbDefs.h"
#include "epicsEvent.h"
#include "epicsMutex.h"
#include "epicsThread.h"
#include "osiSock.h"
#include "epicsAssert.h"
#include "epicsExit.h"
#include "logClient.h"
#ifndef LOCAL
#define LOCAL static
#endif
static const int logClientSuccess = 0;
static const int logClientError = -1;
typedef struct {
char msgBuf[0x4000];
struct sockaddr_in addr;
char name[64];
epicsMutexId mutex;
SOCKET sock;
epicsThreadId restartThreadId;
epicsEventId restartSignal;
unsigned connectTries;
unsigned connectCount;
unsigned connectReset;
unsigned nextMsgIndex;
unsigned connected;
} logClient;
LOCAL const double LOG_RESTART_DELAY = 5.0; /* sec */
LOCAL const unsigned LOG_MAX_CONNECT_RETRIES = 12 * 60;
LOCAL const double LOG_INITIAL_CONNECT_DELAY = 50e-3; /* sec */
LOCAL const unsigned LOG_INITIAL_MAX_CONNECT_RETRIES = 40u;
* logClientClose ()
LOCAL void logClientClose (logClient *pClient)
# ifdef DEBUG
fprintf (stderr, "log client: lingering for connection close...");
fflush (stderr);
# endif
* mutex on
epicsMutexMustLock (pClient->mutex);
* close any preexisting connection to the log server
if ( pClient->sock != INVALID_SOCKET ) {
epicsSocketDestroy ( pClient->sock );
pClient->sock = INVALID_SOCKET;
pClient->connectTries = 0;
pClient->connectReset++;
pClient->nextMsgIndex = 0u;
memset ( pClient->msgBuf, '\0', sizeof ( pClient->msgBuf ) );
pClient->connected = 0u;
* mutex off
epicsMutexUnlock (pClient->mutex);
# ifdef DEBUG
fprintf (stderr, "done\n");
# endif
* logClientReset ()
LOCAL void logClientReset (logClient *pClient)
logClientClose (pClient);
epicsEventSignal (pClient->restartSignal);
* logClientDestroy
LOCAL void logClientDestroy (logClientId id)
logClient *pClient = (logClient *)id;
* mutex on (and left on)
epicsMutexDestroy (pClient->mutex);
free (pClient);
* logClientSend ()
void logClientSend ( logClientId id, const char * message )
logClient * pClient = ( logClient * ) id;
unsigned strSize;
if ( ! pClient || ! message ) {
return;
strSize = strlen ( message );
epicsMutexMustLock ( pClient->mutex );
while ( strSize ) {
unsigned msgBufBytesLeft =
sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
if ( strSize > msgBufBytesLeft ) {
int status;
if ( ! pClient->connected ) {
return;
if ( msgBufBytesLeft > 0u ) {
memcpy ( & pClient->msgBuf[pClient->nextMsgIndex],
message, msgBufBytesLeft );
pClient->nextMsgIndex += msgBufBytesLeft;
strSize -= msgBufBytesLeft;
message += msgBufBytesLeft;
status = send ( pClient->sock, pClient->msgBuf,
pClient->nextMsgIndex, 0 );
if ( status > 0 ) {
unsigned nSent = (unsigned) status;
if ( nSent < pClient->nextMsgIndex ) {
unsigned newNextMsgIndex = pClient->nextMsgIndex - nSent;
memmove ( pClient->msgBuf, & pClient->msgBuf[nSent],
newNextMsgIndex );
pClient->nextMsgIndex = newNextMsgIndex;
else {
else {
char sockErrBuf[64];
if ( status ) {
epicsSocketConvertErrnoToString ( sockErrBuf, sizeof ( sockErrBuf ) );
else {
strcpy ( sockErrBuf, "server initiated disconnect" );
fprintf ( stderr, "log client: lost contact with log server at \"%s\" because \"%s\"\n",
pClient->name, sockErrBuf );
logClientReset ( pClient );
else {
message, strSize );
pClient->nextMsgIndex += strSize;
break;
void epicsShareAPI logClientFlush ( logClientId id )
if ( ! pClient ) {
return;
while ( pClient->nextMsgIndex && pClient->connected ) {
int status = send ( pClient->sock, pClient->msgBuf,
if ( status > 0 ) {
newNextMsgIndex );
else {
else {
if ( status ) {
else {
break;
epicsMutexUnlock ( pClient->mutex );
* logClientMakeSock ()
LOCAL void logClientMakeSock (logClient *pClient)
int status;
osiSockIoctl_t optval;
# ifdef DEBUG
fprintf (stderr, "log client: creating socket...");
# endif
* allocate a socket
pClient->sock = epicsSocketCreate ( AF_INET, SOCK_STREAM, 0 );
if ( pClient->sock == INVALID_SOCKET ) {
fprintf ( stderr, "log client: no socket error %s\n",
sockErrBuf );
return;
optval = TRUE;
status = socket_ioctl (pClient->sock, FIONBIO, &optval);
if (status<0) {
fprintf (stderr, "%s:%d ioctl FBIO client er %s\n",
__FILE__, __LINE__, sockErrBuf);
return;
# ifdef DEBUG
# endif
* logClientConnect()
LOCAL void logClientConnect (logClient *pClient)
int errnoCpy;
int status;
while (1) {
pClient->connectTries++;
status = connect (pClient->sock, (struct sockaddr *)&pClient->addr, sizeof(pClient->addr));
if (status < 0) {
errnoCpy = SOCKERRNO;
if (errnoCpy==SOCK_EISCONN) {
* called connect after we are already connected
* (this appears to be how they provide
* connect completion notification)
break;
else if (errnoCpy==SOCK_EINTR) {
continue;
else if (
errnoCpy==SOCK_EINPROGRESS ||
errnoCpy==SOCK_EWOULDBLOCK ||
errnoCpy==SOCK_EALREADY) {
return;
#ifdef _WIN32
* a SOCK_EALREADY alias used by early WINSOCK
* including this with vxWorks appears to
* cause trouble
else if (errnoCpy==SOCK_EINVAL) {
return;
#endif
else {
if (pClient->connectReset==0) {
fprintf (stderr,
"log client: unable to connect to \"%s\" because %d=\"%s\"\n",
pClient->name, errnoCpy, sockErrBuf);
logClientReset (pClient);
return;
pClient->connected = 1u;
* now we are connected so set the socket out of non-blocking IO
optval = FALSE;
status = socket_ioctl ( pClient->sock, FIONBIO, & optval );
if (status<0) {
fprintf (stderr, "%s:%d ioctl FIONBIO log client error was \"%s\"\n",
return;
* discover that the connection has expired
* (after a long delay)
optval = TRUE;
status = setsockopt (pClient->sock, SOL_SOCKET, SO_KEEPALIVE, (char *)&optval, sizeof(optval));
if (status<0) {
fprintf (stderr, "log client: unable to enable keepalive option because \"%s\"\n", sockErrBuf);
* we don't need full-duplex (clients only write), so we shutdown
* the read end of our socket
status = shutdown (pClient->sock, SHUT_RD);
if (status < 0) {
fprintf (stderr, "%s:%d shutdown(%d,SHUT_RD) error was \"%s\"\n",
__FILE__, __LINE__, pClient->sock, sockErrBuf);
/* not fatal (although it shouldn't happen) */
* set how long we will wait for the TCP state machine
* to clean up when we issue a close(). This
* guarantees that messages are serialized when we
* switch connections.
struct linger lingerval;
lingerval.l_onoff = TRUE;
lingerval.l_linger = 60*5;
status = setsockopt (pClient->sock, SOL_SOCKET, SO_LINGER, (char *) &lingerval, sizeof(lingerval));
if (status<0) {
fprintf (stderr, "log client: unable to set linger options because \"%s\"\n", sockErrBuf);
pClient->connectCount++;
pClient->connectReset = 0u;
fprintf ( stderr, "log client: connected to log server at \"%s\"\n", pClient->name);
* logClientRestart ()
LOCAL void logClientRestart ( logClientId id )
epicsEventWaitStatus semStatus;
while (1) {
semStatus = epicsEventWaitWithTimeout (pClient->restartSignal, LOG_RESTART_DELAY);
assert ( semStatus==epicsEventWaitOK || semStatus==epicsEventWaitTimeout );
if (pClient->sock==INVALID_SOCKET) {
logClientMakeSock (pClient);
continue;
logClientConnect (pClient);
if ( pClient->connectTries>LOG_MAX_CONNECT_RETRIES ) {
fprintf ( stderr, "log client: timed out attempting to connect to %s\n", pClient->name );
else {
logClientFlush ( pClient );
* logClientCreate()
logClientId epicsShareAPI logClientCreate (
struct in_addr server_addr, unsigned short server_port)
unsigned connectTries = 0;
logClient *pClient;
pClient = calloc (1, sizeof (*pClient));
if (pClient==NULL) {
return NULL;
pClient->addr.sin_family = AF_INET;
pClient->addr.sin_addr = server_addr;
pClient->addr.sin_port = htons(server_port);
ipAddrToDottedIP (&pClient->addr, pClient->name, sizeof(pClient->name));
pClient->mutex = epicsMutexCreate ();
if (!pClient->mutex) {
free (pClient);
return NULL;
epicsAtExit (logClientDestroy, (void*) pClient);
pClient->restartSignal = epicsEventCreate (epicsEventEmpty);
if (!pClient->restartSignal) {
free (pClient);
return NULL;
pClient->restartThreadId = epicsThreadCreate ("logRestart",
epicsThreadPriorityLow,
epicsThreadGetStackSize(epicsThreadStackSmall),
logClientRestart, pClient);
if (pClient->restartThreadId==NULL) {
free (pClient);
fprintf(stderr, "log client: unable to start log client connection watch dog thread\n");
return NULL;
* attempt to block for the connect
while ( ! pClient->connected ) {
epicsEventSignal ( pClient->restartSignal );
epicsThreadSleep ( LOG_INITIAL_CONNECT_DELAY );
connectTries++;
if ( connectTries >= LOG_INITIAL_MAX_CONNECT_RETRIES ) {
fprintf (stderr, "log client: unable to connect to \"%s\" for %.1f seconds\n",
pClient->name, LOG_INITIAL_CONNECT_DELAY*LOG_INITIAL_MAX_CONNECT_RETRIES);
break;
return (void *) pClient;
* logClientShow ()
void epicsShareAPI logClientShow (logClientId id, unsigned level)
logClient *pClient = (logClient *) id;
if ( pClient->connected ) {
printf ("log client: connected to log server at \"%s\"\n", pClient->name);
else {
printf ("log client: disconnected from log server at \"%s\"\n", pClient->name);
if (level>1) {
printf ("log client: address=%p, sock=%s, connect tries=%u, connect cycles = %u\n",
(void *) pClient, pClient->sock==INVALID_SOCKET?"INVALID":"OK",
pClient->connectTries, pClient->connectCount);
- Re: R3.14.8 Status/logClient patch Benjamin Franksen
- RE: R3.14.8 Status/logClient patch Jeff Hill
Re: epicsThreadSetPriority called by non epics thread Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
