2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT expand and template constructs
To: [email protected]
Date: Sat, 17 Dec 2005 01:50:40 +0100
Dear Andrew,
I agree with most of what you say, however
you wrote:
> This may be related: In about R3.14.6 we extended macLib so the macro
> expansion syntax may also include a default value, in the form
> $(name=value). The default is used if no macro by that name is found.
>  I suspect this syntax has not been introduced to VDCT yet, and I can
> see that it would cause some complications if you're expecting an
> undefined macro that has a default to remain as a macro in the
> instanciation - maybe you never should.
and later
> I don't like your idea of trying to separate out what you're calling
> a "port macro" and a "string substitution macro" - I assume the
> latter is intended for expansion only in a dbLoadRecords() statement.
>  I don't think you can make this kind of distinction though; in some
> cases the template may have all its macros expanded on the host by a
> parent.vdb file, and in others the same template parameters may be
> provided to dbLoadRecords().
which is somewhat contradictory, I'd say. In the second paragraph you
give a very good reason why retaining an undefined macro makes a lot of
sense (i.e. because I might want to give a value only later e.g. in the
startup file). Or do you propose that in every such case eitehr the
template has a definition a la $(name=$(name)) or the substitution must
be name=$(name)? That would be boring, wouldn't it?
Ben
Re: VDCT expand and template constructs Andrew Johnson
VDCT expand and template constructs Rees, NP (Nick)
Prev: Re: VDCT expand and template constructs Andrew Johnson
Next: Re: VDCT expand and template constructs Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VDCT expand and template constructs Andrew Johnson
