2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT expand and template constructs
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 19 Dec 2005 15:40:55 -0600
Benjamin Franksen wrote:
expansion syntax may also include a default value, in the form
$(name=value). The default is used if no macro by that name is found.
and later
I don't like your idea of trying to separate out what you're calling
a "port macro" and a "string substitution macro" - I assume the
latter is intended for expansion only in a dbLoadRecords() statement.
I don't think you can make this kind of distinction though; in some
cases the template may have all its macros expanded on the host by a
parent.vdb file, and in others the same template parameters may be
provided to dbLoadRecords().
which is somewhat contradictory, I'd say. In the second paragraph you give a very good reason why retaining an undefined macro makes a lot of sense (i.e. because I might want to give a value only later e.g. in the startup file). Or do you propose that in every such case eitehr the template has a definition a la $(name=$(name)) or the substitution must be name=$(name)? That would be boring, wouldn't it?
Actually I don't think there can be any difference in the macLib output between $(name) and $(name=$(name)) whether the 'name' macro is defined or not, since the default value in the latter version is itself subject to macro expansion. The usual behaviour for macLib is not to expand macros that are undefined, leaving the macro syntax in place; I believe that VDCT maintains this behaviour (Nick mentioned this IIRC).
The default value substitution is really only useful to the immediate parent of a template that makes use of it - the only way to override such a default value is to have the named macro defined by the parent. I don't see a major contradicition here though, just a feature with limited usefulness.
Kay-Uwe Kasemir wrote:
On Dec 16, 2005, at 17:59 , Andrew Johnson wrote:
these are subtly different. If a port macro is not resolved then it
shouldn't be an error, I believe it should be treated as if it never
existed in the first place.
I strongly disagree. If a parent diagram is trying to use information from a port that a template it's expanding doesn't actually define, then the parent diagram is wrong and this should cause an error at instantiation time.
I think the naming of these 'text' or 'port' macros isn't 100% clear.
I agree that the term 'port macro' could be confusing; I was quoting Nick's message above, and try to avoid using it myself.
I use the term 'macro' to mean a $(name) substitution, the value of which is set from above; and 'port' to mean a $(instance.name) substitution, the value of which is set by the 'instance' template expansion below. The latter differs somewhat from a 'port' on a hierarchical electronics schematic, but nobody complained about this when we were defining the hierarchical syntax in 2002 and the words 'port' and 'macro' are part of the syntax implemented in VDCT now.
When we compare this to circuit diagrams
or IC pinouts, there are 'input' and 'output' ports.
Comparing EPICS databases with circuit diagrams doesn't work too well in this case, because in EPICS the wires are being used purely for text substitution. If you think about information flow in the template expansion process then a 'port' is always an output from a template and a 'macro' is always an input to one, but that has no relation to the direction that data flows through a link that is configured using a port/macro substitution. If we have a link that crosses a hierarchy then whether we use a port or a macro merely depends on which .vdb file owns the record that contains the link, irrespective of whether the link field itself is an input or an output.
- Andrew
* * Matt Santos / / For a Brighter America * *
RE: VDCT expand and template constructs Rees, NP (Nick)
Re: VDCT expand and template constructs Andrew Johnson
Re: VDCT expand and template constructs Benjamin Franksen
Prev: Re: Ethernet/IP: writing zero to soft tags Kay-Uwe Kasemir
Next: RE: VDCT expand and template constructs Rees, NP (Nick)
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VDCT expand and template constructs Benjamin Franksen
