2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: enhanced seq record
To: [email protected]
Cc: [email protected]
Date: Sat, 28 Jan 2006 01:22:36 +0100
On Saturday 28 January 2006 00:52, Chestnut, Ronald P. wrote:
> If you do change the seq record (or make a new one), can you please
> change the behaviour for a "0" delay? Now a new thread is started for
> each (DOL/LNK) pair. If the delay is zero, can you "just do it" in
> the same thread? We found that for some big "explosions" (nested
> SEQs) the task switching dominates the processing time.
I am quite sure the seq record, as it stands, does not start a new
thread for each link group (=DOL/LNK pair). In R3.13 it uses a watchdog
timer to request a callback and in R3.14 it uses callbackRequestDelayed
(which probably is implemented using such a timer; I didn't look at the
sources).
However, it /does/ request a callback for each group, regardless whether
the delay is zero or not, and this can indeed cause unnecessary context
switches. So, yes, I will change this. Adjacent link groups with zero
delay will be processed in a synchronous manner i.e. w/o requesting a
callback.
Thanks for the hint.
Cheers,
Ben
Re: enhanced seq record Luedeke Andreas
RE: enhanced seq record Chestnut, Ronald P.
Prev: RE: enhanced seq record Mark Rivers
Next: Re: enhanced seq record Tim Mooney
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: enhanced seq record Chestnut, Ronald P.
Next: Re: enhanced seq record Luedeke Andreas
