2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: enhanced seq record
Cc: Benjamin Franksen <[email protected]>, [email protected], [email protected]
Date: Sat, 28 Jan 2006 16:49:59 -0600
Mark Rivers wrote:
Hi Ron,
Are you aware of the "sseq" record in synApps at the APS?
Here is the beginning of the documentation for it:
"The String Sequence record is similar to the Sequence record, and has
all of its capabilities, but it also can link from either string or
double fields to either string or double fields. The record is used to
trigger the processing of up to ten other records and send values to
those records. It is similar to the fanout record, except that it will
fetch an input value and write an output value instead of simply
processing a collection of forward links. It can also specify one of
several selection algorithms that determine which values to write. It
has no associated device support. Its fields fall into the following
categories: "
The most recent version of the sseq record also has the ability to wait
for processing started by its output links to finish before starting
work on the next link.  Each link has a "Wait/noWait" field that can
be modified at run time or at database-configure time.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
RE: enhanced seq record Mark Rivers
Prev: Re: enhanced seq record Benjamin Franksen
Next: Re: enhanced seq record Tim Mooney
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: enhanced seq record Mark Rivers
Next: Patches for ARM Linux target Denison, PN (Peter)
