Hi Ben,
Please reply to core-talk messages on core-talk itself; see
http://www.producingoss.com/html-chunk/setting-tone.html#avoid-private-discussions
for reasons (that book is a good resource for Open Source projects BTW,
with many ideas which I'm trying to introduce to the EPICS community).
- Andrew
Benjamin Franksen wrote:
On Tuesday 21 February 2006 00:21, Andrew Johnson wrote:
severity(): I don't like this; the severity information should be
implicit in the hierarchy of the class that is being thrown. I
expect to be able to write a try/catch phrase that could catch
warnings but not errors or fatalities; I don't want to catch
everything and then have to re-throw anything that's more severe than
a warning. I'm also not convinced that the thrower can determine the
severity of an exception in practice. Therefore I'm not going to
include the severity part.
Hi Andrew & Jeff,
I am not convinced, neither by the argument above ("write a try/catch
phrase that could catch warnings but not errors or fatalities") nor by
the Jeff's design where the severity is a class member.
IMHO, exceptions should not be classified at all into severity types.
Instead, I would propose to create /one/ special exception type that is
reserved for 'assert' style failures, i.e. failures that can only
becaused by broken or corrupted code. IIRC, this is what a 'fatal'
severity normally means in Jeff's code.
All other exceptions are normal (i.e. expected) failure conditions.
Warnings, OTOH, can be automatically logged or whatever, but should
NEVER cause an exception to be thrown. For exceptions to be useful in
any way it is of utmost importance to strictly separate between success
and failure. If the requested operation can be (and is) performed in
any way, an exception must /not/ be thrown.
Why?
A typical operation consists of more than one step, where subsequent
steps depend on the results of preceding ones. If executing step N
results in a 'warning' condition, the code cannot just throw an
exception because this would mean that step N+1 is never performed,
which would in turn mean that the whole operation fails (but with a
'real' error this time, not a warning). Thus, to ensure that the whole
operation can still be performed even in case one of the sub-operations
throws (only) a warning-type exception, each sub-operation must be
executed in it's own try/catch block.
However, if we do this, we gain /absolutely nothing/ compared to the
current (C) method of indicating sucess/failure via return values! To
the contrary, the code will become even more verbose and complicated.
Cheers,
Ben
There is no S in exprexxo.
- Re: 3.15 C++ Exception classes Andrew Johnson
Re: 3.15 C++ Exception classes Kay-Uwe Kasemir
<2006>
2025
2026
RE: 3.15 C++ Exception classes Jeff Hill
<2006>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
