2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15 C++ Exception classes
To: EPICS core-talk <[email protected]>
Date: Tue, 21 Feb 2006 10:51:53 -0600
Benjamin Franksen wrote:
I am not convinced, neither by the argument above ("write a try/catch phrase that could catch warnings but not errors or fatalities") nor by the Jeff's design where the severity is a class member.
IMHO, exceptions should not be classified at all into severity types.
I agree with you; as I said in my penultimate sentence:
> I'm also not convinced that the thrower can determine the severity of
> an exception in practice.
I guess I didn't express all of the reasons for rejecting Jeff's severity() method. My suggestion about being able to catch warnings was not made because I want to do that, but to show that using the exception class hierarchy makes more sense than hiding warning/error information inside the exception object itself.
Instead, I would propose to create /one/ special exception type that is reserved for 'assert' style failures, i.e. failures that can only becaused by broken or corrupted code. IIRC, this is what a 'fatal' severity normally means in Jeff's code.
I think this is very similar to Kay's point, which I will respond to separately...
- Andrew
There is no S in exprexxo.
Re: 3.15 C++ Exception classes Andrew Johnson
Prev: Re: 3.15 C++ Exception classes Andrew Johnson
Next: Fwd: 3.15 C++ Exception classes Kay-Uwe Kasemir
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: 3.15 C++ Exception classes Andrew Johnson
