2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15 C++ Exception classes
To: EPICS core-talk <[email protected]>
Date: Tue, 21 Feb 2006 11:21:01 -0600
Kay-Uwe Kasemir wrote:
On Feb 21, 2006, at 11:36 , Andrew Johnson wrote:
Actually, Benjamin did, and as I said in my reply to his message, can we keep this conversation on core-talk please. Private conversations make these discussions harder to follow, and break up the archive of what was said.
I am not convinced, neither by the argument above ("write a try/ catch phrase that could catch warnings but not errors or fatalities") nor by the Jeff's design where the severity is a class member.
IMHO, exceptions should not be classified at all into severity types.
Instead, I would propose to create /one/ special exception type that is reserved for 'assert' style failures, i.e. failures that can only becaused by broken or corrupted code. IIRC, this is what a 'fatal' severity normally means in Jeff's code. All other exceptions are normal (i.e. expected) failure conditions. Warnings, OTOH, can be automatically logged or whatever, but should NEVER cause an exception to be thrown. For exceptions to be useful in any way it is of utmost importance to strictly separate between success and failure. If the requested operation can be (and is) performed in any way, an exception must / not/ be thrown.
Absolutely. Exceptions are errors from which one can only recover
by backing off, displaying the message and leaving the rest to the user.
Warnings are not exceptions.
There are certainly libraries which like to turn their exception hierarchy into
dissertation matter, but I don't even see the need for a distinction  into
FatalException or NormalException.
What does this code
   try
      loadDatabase("xy.db")
   catch (FatalException &e)
      ...print "FatalException: " + e.what();
   catch (NormalException &e)
      ...print "NormalException: " + e.what();
with end user messages ala
  "FatalException: Divide by 0, null pointer, array overflow, ...."
or
  "NormalException: Syntax error in line 42 of 'xy.db'.
offer to the user that you don't get from
   try
   catch (exception &e)
      ...print e.what();
In both cases, the user wanted to load "xy.db",
can't, and has to figure out why.
Passing a meaningful string for what() is the key.
-Kay
There is no S in exprexxo.
Re: 3.15 C++ Exception classes Andrew Johnson
Prev: Fwd: 3.15 C++ Exception classes Kay-Uwe Kasemir
Next: Re: 3.15 C++ Exception classes Andrew Johnson
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 3.15 C++ Exception classes Andrew Johnson
Next: Fwd: 3.15 C++ Exception classes Kay-Uwe Kasemir
