2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fwd: 3.15 C++ Exception classes
To: Core talk list <[email protected]>
Date: Tue, 21 Feb 2006 12:00:07 -0500
Sorry, also sent this to Andrew on the first reply...
Begin forwarded message:
Date: February 21, 2006 11:59:16 EST
Subject: Re: 3.15 C++ Exception classes
On Feb 21, 2006, at 11:36 , Andrew Johnson wrote:
I am not convinced, neither by the argument above ("write a try/ catch phrase that could catch warnings but not errors or fatalities") nor by the Jeff's design where the severity is a class member. IMHO, exceptions should not be classified at all into severity types. Instead, I would propose to create /one/ special exception type that is reserved for 'assert' style failures, i.e. failures that can only becaused by broken or corrupted code. IIRC, this is what a 'fatal' severity normally means in Jeff's code. All other exceptions are normal (i.e. expected) failure conditions. Warnings, OTOH, can be automatically logged or whatever, but should NEVER cause an exception to be thrown. For exceptions to be useful in any way it is of utmost importance to strictly separate between success and failure. If the requested operation can be (and is) performed in any way, an exception must /not/ be thrown.
Absolutely. Exceptions are errors from which one can only recover
by backing off, displaying the message and leaving the rest to the user.
Warnings are not exceptions.
There are certainly libraries which like to turn their exception hierarchy into dissertation matter, but I don't even see the need for a distinction into
FatalException or NormalException.
What does this code
   try
      loadDatabase("xy.db")
   catch (FatalException &e)
      ...print "FatalException: " + e.what();
   catch (NormalException &e)
      ...print "NormalException: " + e.what();
with end user messages ala
  "FatalException: Divide by 0, null pointer, array overflow, ...."
or
  "NormalException: Syntax error in line 42 of 'xy.db'.
offer to the user that you don't get from
   try
   catch (exception &e)
      ...print e.what();
In both cases, the user wanted to load "xy.db",
can't, and has to figure out why.
Passing a meaningful string for what() is the key.
-Kay
Prev: Re: 3.15 C++ Exception classes Andrew Johnson
Next: Re: 3.15 C++ Exception classes Andrew Johnson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: 3.15 C++ Exception classes Benjamin Franksen
