On Friday 24 February 2006 20:30, Benjamin Franksen wrote:
> I have a working solution. It was a little bit more work than I
> expected at first. As far as I can see at the moment, the basic idea
> is sound, and the code works as specified. The attached file contains
> the patched source files, which are based on R3.14.8.2. I also
> attached a text file that explains solution and limitations.
It seems I forgot to undo the global layout changes in the new
aoRecord.c. This makes it almost impossible to view the (interesting)
differences between old and new version. Sorry about that. I have
attached a new aoRecord.c that contains only the relevant changes,
compared to R3.14.8.2. I also stripped the debug messages to make the
code more readable. Otherwise the code is unchanged.
Ben
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* base/src/rec aoRecord.c,v 1.24.2.1 2004/10/11 22:32:05 anj Exp */
/* aoRecord.c - Record Support Routines for Analog Output records */
* Original Author: Bob Dalesio
* Current Author: Marty Kraimer
* Date: 7-14-89
#include <stddef.h>
#include <stdlib.h>
#include <stdarg.h>
#include <stdio.h>
#include <string.h>
#include "dbDefs.h"
#include "epicsPrint.h"
#include "epicsMath.h"
#include "alarm.h"
#include "cvtTable.h"
#include "dbAccess.h"
#include "dbEvent.h"
#include "dbFldTypes.h"
#include "devSup.h"
#include "errMdef.h"
#include "special.h"
#include "recSup.h"
#include "recGbl.h"
#include "menuConvert.h"
#include "menuOmsl.h"
#define GEN_SIZE_OFFSET
#include "aoRecord.h"
#undef GEN_SIZE_OFFSET
#include "menuIvoa.h"
#include "epicsExport.h"
/* Create RSET - Record Support Entry Table*/
#define report NULL
#define initialize NULL
static long init_record(struct aoRecord *pao, int pass);
static long process();
static long special();
#define get_value NULL
#define cvt_dbaddr NULL
#define get_array_info NULL
#define put_array_info NULL
static long get_units();
static long get_precision();
#define get_enum_str NULL
#define get_enum_strs NULL
#define put_enum_str NULL
static long get_graphic_double();
static long get_control_double();
static long get_alarm_double();
rset aoRSET={
RSETNUMBER,
report,
initialize,
init_record,
process,
special,
get_value,
cvt_dbaddr,
get_array_info,
put_array_info,
get_units,
get_precision,
get_enum_str,
get_enum_strs,
put_enum_str,
get_graphic_double,
get_control_double,
get_alarm_double };
struct aodset { /* analog input dset */
long number;
DEVSUPFUN dev_report;
DEVSUPFUN init;
DEVSUPFUN init_record; /*returns: (0,2)=>(success,success no convert)*/
DEVSUPFUN get_ioint_info;
DEVSUPFUN write_ao;/*(0)=>(success ) */
DEVSUPFUN special_linconv;
epicsExportAddress(rset,aoRSET);
enum prst {
prstIdle, /* not being processed */
prstFetch, /* fetching value via DOL, convert, check alarms */
prstSim, /* getting SIMM via SIML */
prstWrite, /* writing value via device support (or SIML) */
prstFinish /* get timestamp, post monitors, process fwd link */
static void checkAlarms();
static void convert();
static void monitor();
struct aodset *pdset;
double eoff = pao->eoff, eslo = pao->eslo;
double value;
if (pass==0) return(0);
/* ao.siml must be a CONSTANT or a PV_LINK or a DB_LINK */
if (pao->siml.type == CONSTANT) {
recGblInitConstantLink(&pao->siml,DBF_USHORT,&pao->simm);
if(!(pdset = (struct aodset *)(pao->dset))) {
recGblRecordError(S_dev_noDSET,(void *)pao,"ao: init_record");
return(S_dev_noDSET);
/* get the initial value if dol is a constant*/
if (pao->dol.type == CONSTANT) {
if(recGblInitConstantLink(&pao->dol,DBF_DOUBLE,&pao->val))
pao->udf = isnan(pao->val);
/* must have write_ao function defined */
if ((pdset->number < 6) || (pdset->write_ao ==NULL)) {
recGblRecordError(S_dev_missingSup,(void *)pao,"ao: init_record");
return(S_dev_missingSup);
pao->init = TRUE;
/*The following is for old device support that doesnt know about eoff*/
if ((pao->eslo==1.0) && (pao->eoff==0.0)) {
pao->eoff = pao->egul;
if (pdset->init_record) {
long status=(*pdset->init_record)(pao);
if (pao->linr == menuConvertSLOPE) {
pao->eoff = eoff;
pao->eslo = eslo;
switch(status){
case(0): /* convert */
value = (double)pao->rval + (double)pao->roff;
if(pao->aslo!=0.0) value *= pao->aslo;
value += pao->aoff;
if (pao->linr == menuConvertNO_CONVERSION){
; /*do nothing*/
} else if ((pao->linr == menuConvertLINEAR) ||
(pao->linr == menuConvertSLOPE)) {
value = value*pao->eslo + pao->eoff;
}else{
if(cvtRawToEngBpt(&value,pao->linr,pao->init,
(void *)&pao->pbrk,&pao->lbrk)!=0) break;
pao->val = value;
pao->udf = isnan(value);
break;
case(2): /* no convert */
break;
default:
recGblRecordError(S_dev_badInitRet,(void *)pao,"ao: init_record");
return(S_dev_badInitRet);
pao->oval = pao->pval = pao->val;
return(0);
static long process(pao)
struct aoRecord *pao;
struct aodset *pdset = (struct aodset *)(pao->dset);
long status = 0;
double value = pao->val;
unsigned char pact;
if (pao->prst == prstIdle) {
assert(!pao->pact);
pao->prst = prstFetch; /* next processing step */
if (pao->prst == prstFetch) {
if (pao->dol.type != CONSTANT && pao->omsl == menuOmslclosed_loop) {
pao->val = pao->pval; /* don't allow dbputs to val field */
pact = pao->pact;
status = dbGetLinkCallback(&pao->dol, DBR_DOUBLE, &value, 0, 0);
if (status) {
recGblSetSevr(pao, LINK_ALARM, INVALID_ALARM);
} else if (!pact && pao->pact) {
return 0;
} else if (pao->oif == aoOIF_Incremental) {
value += pao->val;
if (!status) {
convert(pao, value); /* this also sets pao->val */
checkAlarms(pao);
pao->prst = prstSim; /* next processing step */
if (pao->nsev == INVALID_ALARM) {
if (pao->ivoa == menuIvoaSet_output_to_IVOV) {
pao->val = pao->ivov;
convert(pao, pao->val);
} else if (pao->ivoa == menuIvoaDon_t_drive_outputs) {
pao->prst = prstFinish; /* next processing step */
pao->pact = FALSE; /* prepare for more asyn calls */
if (pao->prst == prstSim) {
pact = pao->pact;
status = dbGetLinkCallback(&pao->siml, DBR_USHORT, &pao->simm, 0, 0);
if (status) {
return 0; /* to be called again */
pao->prst = prstWrite; /* next processing step */
if (pao->prst == prstWrite && pao->pact) {
/* callback from device support: */
/* it is questionable if this special case makes sense; */
/* however, it is what was always done in aoRecord */
checkAlarms(pao);
if (pao->nsev == INVALID_ALARM && menuIvoaDon_t_drive_outputs) {
if (pao->prst == prstWrite) {
if (!status) {
if (pao->simm && !pao->pact) {
status = dbPutLink(&pao->siol, DBR_DOUBLE, &pao->oval, 1);
recGblSetSevr(pao, SIMM_ALARM, pao->sims);
} else {
pact = pao->pact;
status = pdset->write_ao(pao);
/* check if device support set pact */
if (pao->prst == prstFinish) {
pact = pao->pact;
recGblGetTimeStampCallback(pao);
pao->pact = TRUE;
monitor(pao);
recGblFwdLink(pao);
pao->init = FALSE;
pao->pact = FALSE;
pao->prst = prstIdle;
return status;
static long special(paddr,after)
struct dbAddr *paddr;
int after;
struct aoRecord *pao = (struct aoRecord *)(paddr->precord);
struct aodset *pdset = (struct aodset *) (pao->dset);
int special_type = paddr->special;
switch(special_type) {
case(SPC_LINCONV):
if(pdset->number<6 ) {
recGblDbaddrError(S_db_noMod,paddr,"ao: special");
return(S_db_noMod);
pao->init=TRUE;
if ((pao->linr == menuConvertLINEAR) && pdset->special_linconv) {
double eoff = pao->eoff;
double eslo = pao->eslo;
long status;
status = (*pdset->special_linconv)(pao,after);
if (eoff != pao->eoff)
db_post_events(pao, &pao->eoff, DBE_VALUE|DBE_LOG);
if (eslo != pao->eslo)
db_post_events(pao, &pao->eslo, DBE_VALUE|DBE_LOG);
return (status);
return (0);
default:
recGblDbaddrError(S_db_badChoice,paddr,"ao: special");
return(S_db_badChoice);
static long get_units(paddr,units)
char *units;
struct aoRecord *pao=(struct aoRecord *)paddr->precord;
strncpy(units,pao->egu,DB_UNITS_SIZE);
return(0);
static long get_precision(paddr,precision)
long *precision;
*precision = pao->prec;
if(paddr->pfield == (void *)&pao->val
|| paddr->pfield == (void *)&pao->oval
|| paddr->pfield == (void *)&pao->pval) return(0);
recGblGetPrec(paddr,precision);
return(0);
static long get_graphic_double(paddr,pgd)
struct dbr_grDouble *pgd;
if(paddr->pfield==(void *)&pao->val
|| paddr->pfield==(void *)&pao->hihi
|| paddr->pfield==(void *)&pao->high
|| paddr->pfield==(void *)&pao->low
|| paddr->pfield==(void *)&pao->lolo
|| paddr->pfield==(void *)&pao->oval
|| paddr->pfield==(void *)&pao->pval){
pgd->upper_disp_limit = pao->hopr;
pgd->lower_disp_limit = pao->lopr;
} else recGblGetGraphicDouble(paddr,pgd);
return(0);
static long get_control_double(paddr,pcd)
struct dbr_ctrlDouble *pcd;
pcd->upper_ctrl_limit = pao->drvh;
pcd->lower_ctrl_limit = pao->drvl;
} else recGblGetControlDouble(paddr,pcd);
return(0);
static long get_alarm_double(paddr,pad)
struct dbr_alDouble *pad;
if(paddr->pfield==(void *)&pao->val){
pad->upper_alarm_limit = pao->hihi;
pad->upper_warning_limit = pao->high;
pad->lower_warning_limit = pao->low;
pad->lower_alarm_limit = pao->lolo;
} else recGblGetAlarmDouble(paddr,pad);
return(0);
static void checkAlarms(pao)
double val;
double hyst, lalm, hihi, high, low, lolo;
unsigned short hhsv, llsv, hsv, lsv;
if (pao->udf) {
recGblSetSevr(pao,UDF_ALARM,INVALID_ALARM);
return;
hihi = pao->hihi; lolo = pao->lolo; high = pao->high; low = pao->low;
hhsv = pao->hhsv; llsv = pao->llsv; hsv = pao->hsv; lsv = pao->lsv;
val = pao->val; hyst = pao->hyst; lalm = pao->lalm;
/* alarm condition hihi */
if (hhsv && (val >= hihi || ((lalm==hihi) && (val >= hihi-hyst)))){
if (recGblSetSevr(pao,HIHI_ALARM,pao->hhsv)) pao->lalm = hihi;
return;
/* alarm condition lolo */
if (llsv && (val <= lolo || ((lalm==lolo) && (val <= lolo+hyst)))){
if (recGblSetSevr(pao,LOLO_ALARM,pao->llsv)) pao->lalm = lolo;
return;
/* alarm condition high */
if (hsv && (val >= high || ((lalm==high) && (val >= high-hyst)))){
if (recGblSetSevr(pao,HIGH_ALARM,pao->hsv)) pao->lalm = high;
return;
/* alarm condition low */
if (lsv && (val <= low || ((lalm==low) && (val <= low+hyst)))){
if (recGblSetSevr(pao,LOW_ALARM,pao->lsv)) pao->lalm = low;
return;
/* we get here only if val is out of alarm by at least hyst */
pao->lalm = val;
return;
static void convert(pao,value)
double value;
/* check drive limits */
if(pao->drvh > pao->drvl) {
if (value > pao->drvh) value = pao->drvh;
else if (value < pao->drvl) value = pao->drvl;
pao->val = value;
pao->pval = value;
/* now set value equal to desired output value */
/* apply the output rate of change */
if ( (pao->oroc) != 0.0 ){/*must be defined and >0*/
double diff;
diff = value - pao->oval;
if (diff < 0){
if (pao->oroc < -diff) value = pao->oval - pao->oroc;
}else if (pao->oroc < diff) value = pao->oval + pao->oroc;
pao->omod = (pao->oval!=value);
pao->oval = value;
/* convert */
switch (pao->linr) {
case menuConvertNO_CONVERSION:
break; /* do nothing*/
case menuConvertLINEAR:
case menuConvertSLOPE:
if (pao->eslo == 0.0) value = 0;
else value = (value - pao->eoff) / pao->eslo;
break;
default:
if(cvtEngToRawBpt(&value,pao->linr,pao->init,(void *)&pao->pbrk,&pao->lbrk)!=0){
recGblSetSevr(pao,SOFT_ALARM,MAJOR_ALARM);
return;
value -= pao->aoff;
if(pao->aslo!=0.0) value /= pao->aslo;
if (value >= 0.0) pao->rval = value + 0.5 - pao->roff;
else pao->rval = value - 0.5 - pao->roff;
static void monitor(pao)
unsigned short monitor_mask;
double delta;
monitor_mask = recGblResetAlarms(pao);
/* check for value change */
delta = pao->mlst - pao->val;
if(delta<0.0) delta = -delta;
if (delta > pao->mdel) {
/* post events for value change */
monitor_mask |= DBE_VALUE;
/* update last value monitored */
pao->mlst = pao->val;
/* check for archive change */
delta = pao->alst - pao->val;
if (delta > pao->adel) {
/* post events on value field for archive change */
monitor_mask |= DBE_LOG;
/* update last archive value monitored */
pao->alst = pao->val;
/* send out monitors connected to the value field */
if (monitor_mask){
db_post_events(pao,&pao->val,monitor_mask);
if(pao->omod) monitor_mask |= (DBE_VALUE|DBE_LOG);
if(monitor_mask) {
pao->omod = FALSE;
db_post_events(pao,&pao->oval,monitor_mask);
if(pao->oraw != pao->rval) {
db_post_events(pao,&pao->rval,
monitor_mask|DBE_VALUE|DBE_LOG);
pao->oraw = pao->rval;
if(pao->orbv != pao->rbv) {
db_post_events(pao,&pao->rbv,
pao->orbv = pao->rbv;
return;
- Re: (A)synchronous dbGetLink Benjamin Franksen
Re: Erlang Benjamin Franksen
A question about how to send message in the callback function 赵欢
<2006>
2025
2026
More on the evils of referencing: Iterators verses Callbacks Jeff Hill
<2006>
2025
2026
