> The monitor data format issue might be related to the fixes that Micheal
> Abbot was working on for linux-arm. You may find that you have the
> NetWinder floating point emulation library, which uses a wierd mixed
> endian format. See Mantis #223 for details.
I concur on this guess also although, as memory serves, the middle endian
format applied only to double floating point and so it is initially less
clear what might be occurring with the time stamp (which is stored as two
integers in the CA protocol and therefore the byte swap is presumably
working).
Jeff
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Wednesday, August 23, 2006 8:35 AM
> To: Ralph Lange
> Cc: Jeff Hill; 'Eric Norum'; 'EPICS Core Talk'; 'Ralf Hartmann'
> Subject: Re: osiSockDiscoverBroadcastAddresses(): pointer not
word-aligned?
> Ralph Lange wrote:
> > External CA clients can connect, but get junk in the monitor
> > updates (time stamp and data are garbled).
> - Andrew
> There is considerable overlap between the intelligence
> of the smartest bears and the dumbest tourists.
> -- Yosemite National Park Ranger
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Andrew Johnson
Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
<2006>
2025
2026
<2006>
2025
2026
