2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned?
Cc: Jeff Hill <[email protected]>, "'Eric Norum'" <[email protected]>, "'EPICS Core Talk'" <[email protected]>, "'Ralf Hartmann'" <[email protected]>
Date: Wed, 23 Aug 2006 18:29:41 +0200
We're not using an external FP emulation library, as far as we know.
we just use what the gcc spits out for an ARM that has no FP unit.
Ralph
Andrew Johnson wrote:
Ralph Lange wrote:
External CA clients can connect, but get junk in the monitor updates (time stamp and data are garbled).
The monitor data format issue might be related to the fixes that Micheal Abbot was working on for linux-arm. You may find that you have the NetWinder floating point emulation library, which uses a wierd mixed endian format. See Mantis #223 for details.
- Andrew
RE: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Jeff Hill
Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Andrew Johnson
Prev: RE: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Jeff Hill
Next: Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
