Hm...
Ralf added some code to osiSockDiscoverBroadcastAddresses() that
memcpy-copies the odd-length ifreq into a word-aligned buffer, then uses
a pointer to this aligned copy to hand to the subsequent calls.
Effect: The RTEMS board boots, doesn't crash, and finds four interfaces
(lo: and eth0: both appear twice), two of which it recognizes as
AF_INET. External CA clients can connect, but get junk in the monitor
updates (time stamp and data are garbled).
So it seems that the returned ifreq length of 70 for the first interface
really is the reason for crashing on the second entry which is not aligned.
Would you see the additional buffer as an adequate way to handle this?
(Probably not...)
If not, where in the BSD network code would we have to add the padding?
Does the CA data garbling point to the same problem or to something else?
Ralph & Ralf
Jeff Hill wrote:
Agree with Eric's comment.
So you might have a closer look at ifreq_size ensuring that it's functioning
properly implemented for your ARM RTEMS. See examples below.
Jeff
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Andrew Johnson
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
- RE: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Jeff Hill
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
