You need to figure out why ifreq_size is returning the wrong value. The macro definition for RTEMS (src/libCom/osi/os/RTEMS/osdSock.h) is: #define ifreq_size(pifreq) (pifreq->ifr_addr.sa_len + sizeof(pifreq->ifr_name))
You could add some code to check, but I'm pretty sure that the sizeof(pifreq->ifr_name) is 16. So you need to figure out why the pifreq->ifr_addr.sa_len is unreasonable. Check the network driver initialization code and see if it's doing something odd.
On Aug 23, 2006, at 9:05 AM, Ralph Lange wrote: Hm...
Ralf added some code to osiSockDiscoverBroadcastAddresses() that memcpy-copies the odd-length ifreq into a word-aligned buffer, then uses a pointer to this aligned copy to hand to the subsequent calls.
Effect: The RTEMS board boots, doesn't crash, and finds four interfaces (lo: and eth0: both appear twice), two of which it recognizes as AF_INET. External CA clients can connect, but get junk in the monitor updates (time stamp and data are garbled).
I'm not sure what exactly you did here. Did you modify ifreqNext to always use sizeof (*pifreq) as the offset to the next address entry? I can't see how you could step through the addresses otherwise.
So it seems that the returned ifreq length of 70 for the first interface really is the reason for crashing on the second entry which is not aligned.
Yes, likely because the 70 is ridiculous and you end up looking at some random memory contents for the second entry.
Would you see the additional buffer as an adequate way to handle this? (Probably not...) If not, where in the BSD network code would we have to add the padding?
I don't think that this is an issue of padding. It's an issue of a bad sa_len getting in there somewhere. If you have the ability to put in watchpoints it would be useful to see each time that memory location was written to. -- Advanced Photon Source Argonne National Laboratory (630) 252-4793 |
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
- RE: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Jeff Hill
Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Andrew Johnson
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
