2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting alh to run on AMD64 (linux 64-bit OS)
To: "Ernest L. Williams Jr." <[email protected]>
Cc: "Sinclair, John William" <[email protected]>, EPICS core-talk <[email protected]>
Date: Tue, 31 Oct 2006 14:53:46 -0600
Ernest L. Williams Jr. wrote:
John Sinclair has been working with us to run alh under linux_x86_64 and
has found that the alh core dumps at run time due to the definition of
NULL that comes from EPICS BASE.
dbDefs.h:#if     defined(NULL)
dbDefs.h:#undef NULL
dbDefs.h:#define NULL    0
dbDefs.h:#define NONE            (-1)    /* for times when NULL won't do
dbDefs.h:#define PVNAME_STRINGSZ                61              /*
includes NULL terminator for PVNAME_SZ */
What is the recommended way to move forward on this?
Could we just get rid of the definition in dbDefs.h or will that break
some legacy apps?
Notwithstanding all the language lawyer comments about how NULL should be defined, removing the definition from dbDefs.h does not break the build of Base (on Linux, solaris and vxWorks 5.4 at least, I haven't checked the other archs), so I think we should remove it. According to my K&R Second Edition, NULL is defined in stdio.h, although that might have moved to stddef.h in more recent versions. Unless someone screams it will be gone by R3.14.9. This doesn't mean that we shouldn't fix alh, but having our own definition of NULL is obviously a Bad Thing anyway.
I'm about to add a response to the more detailed argument going on between John & Eric...
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Prev: RE: GCC 4 warnings in EPICS Base Jeff Hill
Next: Re: Getting alh to run on AMD64 (linux 64-bit OS) Andrew Johnson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
