2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Q: revision strings
To: Ralph Lange <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Thu, 16 Nov 2006 13:39:29 -0600
Ralph Lange wrote:
I know you had an idea for that, but I can't find the mail, so:
Is there a smart way to get revision strings (static const char *id =
"@(#) ...") into C code without producing a compiler warning?
I was using a construct like this:
static const struct sccsid {struct sccsid *p; char *id; } sccsid = {
    &id, "$Id$"
But I just discovered online that the right way to do it seems to be this:
static const char sccsid[] = "$Id$";
When using an array instead of a pointer, gcc doesn't warn.
I'm about to commit that * => [] change to src/ca/cac.cpp, src/misc/epicsRelease.c, src/cas/generic/caServerI.cc, src/libCom/osi/devLib.c and src/libCom/osi/epicsTime.cpp to fix the warnings from those files...
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Prev: Re: 3.14.9 schedule Andrew Johnson
Next: R3-14-9-pre1 on Monday Andrew Johnson
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
