2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building Posix for win32-x86?
To: Jeff Hill <[email protected]>
Cc: Janet Anderson <[email protected]>, "'EPICS Core Talk'" <[email protected]>
Date: Tue, 21 Nov 2006 10:06:40 -0600
Jeff,
Jeff Hill wrote:
I am chasing down an infinite recursion during init that appears to occur on
win32-x86 because of an assert failure in epicsThreadOnce. I suspect that
this is a side effect of a cvs update I did before I committed files on
Friday.
I did commit this change to libCom/osi/os/WIN32/osdThread.c about 2 weeks ago, in epicsThreadOnceOsd():
Index: osdThread.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/osi/os/WIN32/osdThread.c,v
retrieving revision 1.52.2.13
retrieving revision 1.52.2.14
diff -u -b -r1.52.2.13 -r1.52.2.14
--- osdThread.c 11 Nov 2005 01:47:07 -0000      1.52.2.13
+++ osdThread.c 10 Nov 2006 20:19:34 -0000      1.52.2.14
@@ -999,10 +999,12 @@
     EnterCriticalSection ( & pGbl->mutex );
-    if ( ! *id ) {
+    if ( *id == 0 ) {
+        *id = -1;
         ( *func ) ( arg );
         *id = 1;
+    } else
+        assert(*id > 0 /* func() called epicsThreadOnce() with same id */);
     LeaveCriticalSection ( & pGbl->mutex );
The purpose of this assertion is to detect a situation that the posix version of epicsThreadOnceOsd() is unable to handle or even detect since posix mutexes are not recursive. This might cause an infinite loop if assert() calls errlogInit() which calls epicsThreadOnce(), but that situation could only occur if func() has itself first called epicsThreadOnce() with the same id.
When attempting to fix that I am seeing a real weird situation where it is
building posix code when EPICS_HOST_ARCH == WIN32-x86.
I have no explanation for that.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: building Posix for win32-x86? Jeff Hill
Prev: building Posix for win32-x86? Jeff Hill
Next: RE: building Posix for win32-x86? Jeff Hill
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
