2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C strict aliasing rules
To: Eric Norum <[email protected]>
Cc: Core talk list <[email protected]>
Date: Mon, 27 Nov 2006 12:23:14 -0600
Eric Norum wrote:
static inline void
writethree(int *p)
    short *palias = (short *)p;
   *palias = 3;
int
testalias()
    int value = 12345678;
    writethree(&value);
    return value;
One might expect that the value returned from testalias() would be 12345678 with either its most-significant 16 bits or least- significant 16 bits set to 3 (on most architectures).
One would be wrong, though.
I don't think life is quite as bad as it might seem; if you take off the "static inline" keywords from writethree(), I suspect the optimizer may not be able to be quite as aggressive in throwing out code - please experiment and respond to that suggestion.
Since we don't (shouldn't?) have any C routines in base that are marked as "static inline", I don't think our problems are as large as you make out them to be. I suspect the rules for C++ are subtly different, so it would also be interesting to see what using the C++ compiler generates.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: C strict aliasing rules Eric Norum
Prev: C strict aliasing rules Eric Norum
Next: Re: C strict aliasing rules Eric Norum
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
