2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C strict aliasing rules
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 27 Nov 2006 20:02:38 -0600
On Nov 27, 2006, at 7:20 PM, Benjamin Franksen wrote:
Cheers
Ben
PS: whatever happened to the notorious compiler warning 'xyz disables
strict aliasing rules'? Seems to me as if compilers once were able to
detect cases where the assumptions broke down. Hmmm.
The explicit cast is what's suppressing any warning. Unfortunately I expect that we have lots of casts in EPICS which might cause similar (and silent) problems. FWIW, here's a version of the code that actually does produce the warning to which Benjamin is referring:
norume@gnarly 704> cat a.c
void
writethree(short *p)
    short *palias = p;
   *palias = 3;
int
testalias()
    int value = 12345678;
    writethree((short *)&value);
    return value;
norume@gnarly 705> m68k-rtems4.7-gcc -O4 -Wall -S a.c
a.c: In function 'testalias':
a.c:12: warning: dereferencing type-punned pointer will break strict- aliasing rules
So, do we:
1) Ensure that EPICS is built with an optimization level that doesn't use the strict aliasing rules?
or
2) Explictly prevent the compiler from using the strict aliasing rules (-fnostrict-aliasing for gcc, ??? for other compilers)?
or
3) Bury our heads in the sand and hope that the problem never arises in our code?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: C strict aliasing rules Benjamin Franksen
C strict aliasing rules Eric Norum
Re: C strict aliasing rules Andrew Johnson
Re: C strict aliasing rules Eric Norum
Prev: Re: C strict aliasing rules Benjamin Franksen
Next: Re: C strict aliasing rules Benjamin Franksen
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
