2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ compiler issues
To: Jeff Hill <[email protected]>
Cc: Janet Anderson <[email protected]>, Andrew Johnson <[email protected]>, EPICS Core Talk <[email protected]>, Stephanie Allison <[email protected]>
Date: Tue, 12 Dec 2006 15:17:47 -0500
On Tue, 2006-12-12 at 11:47 -0700, Jeff Hill wrote:
> Hi,
> I don't know how you feel about the Borland build not working so far with
> R3.14.9? I, for one, am feeling some guilt primarily because we have
> supported the Borland compiler with past R3.14 releases.
> I could fix this problem, but from another perspective there are available
> for free cygwin, mingw, and MS tools for native win32 builds, and Borland
> hasn't made a new release of their free compiler since the year 2000. Soon
> that will be seven years ago which actually is quite a long time in computer
> science years (computer science years run slightly faster than dog and cat
> years btw). My guess is that if you are willing to buy the Borland compiler
> that that version will include a standards compliant compiler.
> Does CEBAF still use HPUX? Apparently JAERI (and probably also KEK) servers
> are HPUX? Do they have modern HPUX versions with modern C++ compilers?
> It's unclear to me how often the VMS C++ compiler is updated. Maybe more
> often than one might initially guess given that the same compiler is I
> suspect available for both VMS and ULTRIX?
> PS: I noticed today that maybe Java, as released by Sun, is available now
> only for Windows, Linux, and Solaris? Do I understand that correctly?
> Presumably other commonly used Unix variants (such as BSD Unix) must get the
> source and self support?
> PPS: I think I understand that WRS supports currently as development hosts
> only Linux, Solaris, and Windows.
I also understand the same.  If you do anything different you are on
your own.
-- Ernest
> Jeff
> __________________________________________________________
> Jeffrey O. Hill               Mail         [email protected]
> LANL MS H820                  Voice        505 665 1831
> Los Alamos NM 87545 USA       Fax          505 665 5107
C++ compiler issues Jeff Hill
Prev: Re: C++ compiler issues Kay-Uwe Kasemir
Next: Re: C++ compiler issues Christopher Larrieu
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
