2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ Exceptions from CAC-UDP on exit
To: EPICS core-talk <[email protected]>
Date: Wed, 13 Dec 2006 17:23:49 -0600
Update: I'm seeing this in other applications where access security is not involved but where two IOCs are linked together. For example, in the iocconvert tests I started the client IOC after and stopped it before the master IOC, with this result:
uranus% ../../bin/linux-x86/convert client.main
dbLoadDatabase("../../dbd/convert.dbd",0,0)
convert_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("../../convertApp/Db/convertClient.db",0)
dbLoadRecords("../../convertApp/Db/convertClientENUM.db",0)
iocInit()
Starting iocInit
## EPICS R3.14.9-CVS $$Name:  $$ $$Date: 2006/12/11 22:32:14 $$
## EPICS Base built Dec 11 2006
iocInit: All initialization complete
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 37984,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
epics> epicsThread: Unknown C++ exception in thread "CAC-UDP" at Wed Dec 13 2006 17:18:55.22003000
terminate called after throwing an instance of ''
FATAL: exception not rethrown
Abort
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Re: C++ Exceptions from CAC-UDP on exit Ernest L. Williams Jr.
C++ Exceptions from CAC-UDP on exit Andrew Johnson
Prev: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Next: Bug in generated MakefileInclude? Benjamin Franksen
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
