2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: C++ Exceptions from CAC-UDP on exit
To: EPICS core-talk <[email protected]>
Date: Wed, 13 Dec 2006 13:52:39 -0600
I've been running Marty's mrkSoftTest accessApp code, and I've noticed that when shutting down the accessRemote IOC in the IOC-IOC test, I get the following message on exit if the accessLocal IOC was started after the accessRemote IOC and is still running:
uranus% ../../bin/linux-x86/access accessRemote.main
asSetFilename("../../accessApp/acf/remote.acf")
dbLoadDatabase("../../dbd/access.dbd")
access_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("../../accessApp/db/remote.db")
iocInit
Starting iocInit
## EPICS R3.14.9-CVS $$Name:  $$ $$Date: 2006/12/11 22:32:14 $$
## EPICS Base built Dec 11 2006
iocInit: All initialization complete
start accessLocal IOC at this point, which causes the following output on this IOC:
epics> dbCaTask ca_get_callback Read access denied
mrkREMOTEprotectedRB has DB CA link to mrkLOCALprotected
mrkREMOTEprotected has DB CA link to mrkLOCALprotected
Now shut down this IOC, either with exit or just Ctrl-D:
epics> exit
epicsThread: Unknown C++ exception in thread "CAC-UDP" at Wed Dec 13 2006 13:06:48.21231000
terminate called after throwing an instance of ''
FATAL: exception not rethrown
epicsThread: Unknown C++ exception in thread "CAC-UDP" at Wed Dec 13 2006 13:06:48.21843000
terminate called recursively
CA client library tcp receive thread terminating due to a C++ exception
Abort
If I shut down the accessLocal IOC first, no exception messages appear. This problem only happens when I get the "Read access denied" messages. The two IOCs can be on the same or on different linux hosts to see the problem, but it doesn't appear if I run either of them on solaris, even when I get the "Read access denied" messages. There is probably some connection with the host names in the access security configuration files, because it doesn't occur if I run the accessRemote IOC on a linux machine that isn't listed in the HAG on the accessLocal IOC, but if I add that IOC to the HAG there it does occur.
Jeff -- any ideas? I realize this problem may be somewhat tricky to trace, and since it's a shutdown issue I don't think it's a show-stopper - the process does exit, just not cleanly in this circumstance. If you want to try and replicate it, follow the instructions in the mrkSoftTest/accessApp/README file.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Prev: Re: C++ compiler issues Christopher Larrieu
Next: Re: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
