Hi Kazuro,
Kazuro FURUKAWA wrote:
I've updated my (dirty) patch for Tru64unix at
<URL:http://www-linac.kek.jp/jk/osf/base-3.14.9-pre2-osf-alpha.patch>
Janet is committing most of these changes (slightly modified) to CVS,
and also removing the src/libCom/osi/os/alpha directory which your
README says you don't use any more.
I have asked Jeff Hill to comment on the change you're making to the
src/ca/comBuf.h file - I don't see why this should be necessary if it's
not needed on other architectures. He hasn't responded yet though, and
we won't commit that change without his agreement.
Its test results are not optimal yet as in
<URL:http://www-linac.kek.jp/jk/osf/base-3.14.9-pre2-test-osf.txt>
But I believe they are minor.
You can manually run the src/libCom/test/O.osf-alpha/epicsStdioTest and
src/libCom/test/O.osf-alpha/epicsTimerTest programs to see what the
errors are actually reporting. The epicsStdioTest failures imply that
your system's vsnprintf() routine doesn't return the correct value. You
can fix this by creating a src/libCom/osi/os/osf/osdStdio.c file (copy
and modify the posix version) to correct the OS error.
To me comBuf.h seems to be OK, but ... If you have any idea to try,
please let me know. But again, essentially I don't need R3.14.9 on
HP-UX at KEKB and Linac. So please don't be bothered too much.
That seems like a very strange error message.
By the way, to my understanding you kindly picked up Artem's FreeBSD
configuration. Thank you very much.
We're happy to include new architectures in the official release,
although we can't always test them ourselves so we will have to rely on
the donor doing the testing for us.
I've also asked him to build a sort of the unit-test environment for
EPICS. And I realized that you already built it using Perl's Test
environment. Thanks for that. He may restart the process based on
your efforts. I think such tools may enhance the reliability of
EPICS installations very much.
I hope he/you will adopt the testing setup that we've included. I'm
looking to expand the testing in Base by incorporating many of the tests
from Marty Kraimer's mrkSoftTest application where these can be easily
automated. Unfortunately automatically running tests on vxWorks and
RTEMS may be impossible to do, but any automation of this sort can only
increase the amount of testing that gets done, thus improving the
quality of EPICS Base releases.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
Re: Problems with database breakpoint routines. Andrew Johnson
RE: Problems with database breakpoint routines. Rees, NP (Nick)
<2006>
2025
2026
<2006>
2025
2026
