Hi Nick,
Rees, NP (Nick) wrote:
Thanks. Could you send me the revised files back so we don't get out of
sync. I have been doing a bit more investigation and there are still
some issues. I'd like to sort it out so I understand it.
Attached: the breakpoint changes since the official R3.14.9-pre2
release. Apply patch in the base/src directory.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Index: db/dbAccess.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbAccess.c,v
retrieving revision 1.116.2.10
retrieving revision 1.116.2.11
diff -u -b -r1.116.2.10 -r1.116.2.11
--- db/dbAccess.c 6 Dec 2006 17:10:26 -0000 1.116.2.10
+++ db/dbAccess.c 19 Dec 2006 16:20:47 -0000 1.116.2.11
@@ -535,7 +535,7 @@
/* see if there are any stopped records or breakpoints */
- if (lset_stack_not_empty) {
+ if (lset_stack_count != 0) {
* Check to see if the record should be processed
* and activate breakpoint accordingly. If this
@@ -624,7 +624,7 @@
/* process record */
status = (*prset->process)(precord);
/* Print record's fields if PRINT_MASK set in breakpoint field */
dbPrint(precord);
all_done:
Index: db/dbBkpt.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbBkpt.c,v
retrieving revision 1.29
retrieving revision 1.29.2.1
diff -u -b -r1.29 -r1.29.2.1
--- db/dbBkpt.c 12 Jul 2002 21:33:40 -0000 1.29
+++ db/dbBkpt.c 19 Dec 2006 16:20:47 -0000 1.29.2.1
@@ -141,7 +141,7 @@
* normal record execution, i.e. when there aren't
* any breakpoints set.
-long lset_stack_not_empty = 0;
+long lset_stack_count = 0;
* Stack--in which each entry represents a different
@@ -154,7 +154,7 @@
* operating with this stack.
static ELLLIST lset_stack;
-static epicsMutexId bkpt_stack_sem;
+static epicsMutexId bkpt_stack_sem = 0;
* Stores the last lockset continued or stepped from.
@@ -251,6 +251,18 @@
+ * Initialise the breakpoint stack
+void epicsShareAPI dbBkptInit(void)
+ if (! bkpt_stack_sem) {
+ bkpt_stack_sem = epicsMutexMustCreate();
+ ellInit(&lset_stack);
+ lset_stack_count = 0;
* Add breakpoint to a lock set
* 1. Convert name to address and check breakpoint mask.
* 2. Lock database.
@@ -290,17 +302,6 @@
* Add lock set to the stack of lock sets that
* contain breakpoints and/or stopped records.
- if (! lset_stack_not_empty) {
- /* initialize list and semaphore */
- bkpt_stack_sem = epicsMutexCreate();
- if (bkpt_stack_sem == 0) {
- printf(" BKPT> epicsMutexCreate failed\n");
- dbScanUnlock(precord);
- return(1);
- ellInit(&lset_stack);
- lset_stack_not_empty = 1;
epicsMutexMustLock(bkpt_stack_sem);
@@ -335,7 +336,9 @@
pnode->taskid = 0;
pnode->step = 0;
pnode->l_num = dbLockGetLockId(precord);
ellAdd(&lset_stack, (ELLNODE *)pnode);
+ ++lset_stack_count;
@@ -604,11 +607,11 @@
/* Reset precord. (Since no records are at a breakpoint) */
pnode->precord = NULL;
- while (ellCount(&pnode->bp_list) != 0);
+ } while (ellCount(&pnode->bp_list) != 0);
/* remove node from lockset stack */
ellDelete(&lset_stack, (ELLNODE *)pnode);
+ --lset_stack_count;
@@ -634,14 +637,6 @@
/* free list node */
free(pnode);
- /* if last node on stack ... */
- if (ellCount(&lset_stack) == 0) {
- /* Unset flag, delete stack semaphore */
- lset_stack_not_empty = 0;
- epicsMutexDestroy(bkpt_stack_sem);
epicsMutexUnlock(bkpt_stack_sem);
Index: db/dbBkpt.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbBkpt.h,v
retrieving revision 1.11.2.1
retrieving revision 1.11.2.2
diff -u -b -r1.11.2.1 -r1.11.2.2
--- db/dbBkpt.h 6 Dec 2006 17:10:26 -0000 1.11.2.1
+++ db/dbBkpt.h 19 Dec 2006 16:20:47 -0000 1.11.2.2
@@ -82,6 +82,7 @@
#define MAX_EP_COUNT 99999
+epicsShareFunc void epicsShareAPI dbBkptInit(void);
epicsShareFunc long epicsShareAPI dbb(const char *recordname);
epicsShareFunc long epicsShareAPI dbd(const char *recordname);
epicsShareFunc long epicsShareAPI dbc(const char *recordname);
@@ -90,11 +91,11 @@
epicsShareFunc long epicsShareAPI dbp(
const char *record_name, int interest_level);
epicsShareFunc long epicsShareAPI dbap(const char *record_name);
-epicsShareFunc int epicsShareAPI dbBkpt(dbCommon *precord);
-epicsShareFunc void epicsShareAPI dbPrint(dbCommon *precord);
+epicsShareFunc int epicsShareAPI dbBkpt(struct dbCommon *precord);
+epicsShareFunc void epicsShareAPI dbPrint(struct dbCommon *precord);
epicsShareFunc long epicsShareAPI dbprc(char *record_name);
-extern long lset_stack_not_empty;
+extern long lset_stack_count;
#ifdef __cplusplus
Index: misc/iocInit.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/misc/iocInit.c,v
retrieving revision 1.11.2.4
retrieving revision 1.11.2.5
diff -u -b -r1.11.2.4 -r1.11.2.5
--- misc/iocInit.c 31 Oct 2005 20:54:10 -0000 1.11.2.4
+++ misc/iocInit.c 19 Dec 2006 16:29:38 -0000 1.11.2.5
@@ -1,14 +1,13 @@
-* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+* Copyright (c) 2006 UChicago Argonne LLC, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
-* EPICS BASE Versions 3.13.7
-* and higher are distributed subject to a Software License Agreement found
+* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* iocInit.c ioc initialization */
-/* base/src/db $Id: iocInit.c,v 1.11.2.4 2005/10/31 20:54:10 anj Exp $ */
+/* $Id: iocInit.c,v 1.11.2.5 2006/12/19 16:29:38 anj Exp $ */
/* Author: Marty Kraimer Date: 06-01-91 */
@@ -27,6 +26,7 @@
#include "dbBase.h"
#include "caeventmask.h"
#include "dbAddr.h"
+#include "dbBkpt.h"
#include "dbFldTypes.h"
#include "link.h"
#include "dbLock.h"
@@ -125,6 +125,7 @@
interruptAccept=TRUE; initHooks(initHookAfterInterruptAccept);
epicsThreadSleep(1.0);
+ dbBkptInit();
/* Start up CA server */
rsrv_init();
- RE: Problems with database breakpoint routines. Rees, NP (Nick)
Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
<2006>
2025
2026
Re: EPICS on Tru64unix and HP-UX Andrew Johnson
<2006>
2025
2026
