Hello -
part of a proper "professional" soft IOC setup is having a PID file that
the system scripts can use to selectively start/stop soft IOCs as
required. Through multiple forks, shells and a screen session, it is
hard to determine the PID of the soft IOC from the startup script. My
solution was exporting an environment variable PIDFILE into that chain
of fork/shell/screen and have the soft IOC itself create the PID file,
if that environment variable is set.
http://www.aps.anl.gov/epics/wiki/index.php/How_to_Set_Up_a_Soft_IOC_Framework_on_Linux#Make_the_Soft_IOC_Create_the_PID_File
shows the code I added to my soft IOCs.
Does anyone see any possible side-effects? Would that code be
Windows-proof? Should I integrate it into the example stuff in base to
make it standard?
Ralph
- Re: SoftIocMain.cpp Andrew Johnson
Re: lock ownership enforcement in OO design Andrew Johnson
<2007>
2025
2026
Re: lock ownership enforcement in OO design Kay-Uwe Kasemir
<2007>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
