2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Possible Bug in 3.14.9 Access Security on mv2100
To: "'Ralph Lange'" <[email protected]>, "'Steven Hartman'" <[email protected]>, "'EPICS core-talk'" <[email protected]>
Date: Thu, 9 Aug 2007 10:33:46 -0600
> More observations from Steven:
> Now, I just rebuilt all of base on linux with HOST_OPT=NO. Even stranger.
> Using optimized build on linux, caget failed with an unexpected read
> access error 19 out of 20 times just tested. Using non-optimized build
> on linux, caget failed 2 out of 20 times!
This appears to be a major hint. I need to confirm that the behavior changed
this way (as described above) when the CA client library's optimization
level changes, and that during this experiment the IOC's optimization level
was not changed.
Jeff
-----Original Message-----
On Behalf Of Ralph Lange
Sent: Wednesday, August 08, 2007 9:46 AM
To: EPICS Tech Talk
Subject: Re: Possible Bug in 3.14.9 Access Security on mv2100
More observations from me:
I can also see the faulty behaviour against a Linux 3.14.9 IOC.
Including the statistical behaviour that Steven was reporting. Some of
the caget calls get the unexpected "no read", others don't. On the same
Linux host, caget fails about 20%. Cross to vxWorks mv2100 IOC, caget
fails 100%. Camonitor works all the time, against all type IOCs.
Rebuilding Base 3.14.9 with the as subdirectory from 3.14.8.2 does not
change the faulty behaviour at all. The as parser cleanup things got away.
I already have optimization turned off for the cross compiler (have been
bit by that on VxWorks before) but have host optimization on. I tried
turning off host optimization and recompiling caget on linux, but the
problem remained.
Houston, we have a problem.
Ralph
RE: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
Re: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Prev: Re: Pre-Release Tests of EPICS Base Andrew Johnson
Next: RE: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Pre-Release Tests of EPICS Base Jeff Hill
