Note that the setup of my original system was:
vxWorks:
Using the same 3.14.8.2. (optimized) client, the faulty behaviour (100%)
appears with 3.14.9 (optimized) IOCs, and does not appear with 3.14.8.2
(optimized) IOCs.
Linux:
Using the same 3.14.8.2 (optimized) client, the faulty behaviour (20%)
appears with a 3.14.9 (optimized) soft IOC, and does not appear with a
3.14.8.2 (optimized) soft IOC.
Ralph
Jeff Hill wrote:
More observations from Steven:
Now, I just rebuilt all of base on linux with HOST_OPT=NO. Even stranger.
Using optimized build on linux, caget failed with an unexpected read
access error 19 out of 20 times just tested. Using non-optimized build
on linux, caget failed 2 out of 20 times!
This appears to be a major hint. I need to confirm that the behavior changed
this way (as described above) when the CA client library's optimization
level changes, and that during this experiment the IOC's optimization level
was not changed.
Jeff
- RE: Possible Bug in 3.14.9 Access Security on mv2100 Jeff Hill
RE: Pre-Release Tests of EPICS Base Jeff Hill
generalTime update Kalantari Babak
<2007>
2025
2026
RE: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
<2007>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
