I received the attached patch from Eric Berryman, which I'm posting here
for additional comments. The change should not break existing
asTrapWrite plug-ins since it merely adds fields to the message
structure that contains all of the information about the write being
performed — the fields it adds contain the new data and metadata from
the put. However it does increase the size of the asTrapWriteMessage
structure from 4 to 7 pointers.
I can see that it simplifies the use of the asTrapWrite API, but I am
not convinced that it is strictly necessary. The existing API does not
provide the put data & metadata directly, but this information can be
obtained from the record field by the 'after' call to the registered
plug-in. This would not be true if the put causes record processing
which modifies the value of the field before the 'after' call, but by
forcing users to fetch the 'after' data they also find out what the real
effect was of that put, not just what the client tried to do (if you
rely only on what was in the put buffer as provided by this patch you
can't be 100% sure what value actually ended up in the field).
Comments, positive or negative?
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
--- /opt/epicsB/base_old/src/as/asLib.h 2007-09-24 13:11:43.000000000 -0400
+++ /opt/epicsB/base/src/as/asLib.h 2007-09-24 13:28:44.969781176 -0400
@@ -42,9 +42,9 @@
(asActive \
? ((asClientPvt)->access>=asWRITE ? TRUE : FALSE)\
: TRUE)
-#define asTrapWriteBefore(asClientPvt,user,host,addr) \
+#define asTrapWriteBefore(asClientPvt,user,host,addr,dtype,dptr,dcnt) \
(((asActive) && (asClientPvt)->trapMask) \
- ? asTrapWriteBeforeWrite((user),(host),(addr)) \
+ ? asTrapWriteBeforeWrite((user),(host),(addr),(dtype),(dptr),(dcnt)) \
: 0)
#define asTrapWriteAfter(pvt) if((pvt)) asTrapWriteAfterWrite((pvt))
@@ -101,7 +101,7 @@
epicsShareFunc int epicsShareAPI asDumpHashFP(FILE *fp);
epicsShareFunc void * epicsShareAPI asTrapWriteBeforeWrite(
- const char *userid,const char *hostid,void *addr);
+ const char *userid,const char *hostid,void *addr,unsigned short dataType,void *dataptr,unsigned long count);
epicsShareFunc void epicsShareAPI asTrapWriteAfterWrite(void *pvt);
--- /opt/epicsB/base_old/src/as/asTrapWrite.h 2007-09-24 13:11:43.000000000 -0400
+++ /opt/epicsB/base/src/as/asTrapWrite.h 2007-09-24 13:24:48.000000000 -0400
@@ -24,6 +24,9 @@
const char *hostid;
void *serverSpecific;
void *userPvt;
+ unsigned short *dataType;
+ void *dataptr;
+ unsigned long *count;
} asTrapWriteMessage;
--- /opt/epicsB/base_old/src/as/asTrapWrite.c 2007-09-24 13:57:45.117261852 -0400
+++ /opt/epicsB/base/src/as/asTrapWrite.c 2007-09-24 13:21:17.000000000 -0400
@@ -112,7 +112,7 @@
writeMessage *pwriteMessage;
listener *plistener;
@@ -125,6 +125,9 @@
pwriteMessage->message.userid = userid;
pwriteMessage->message.hostid = hostid;
pwriteMessage->message.serverSpecific = addr;
+ pwriteMessage->message.dataType = dataType;
+ pwriteMessage->message.dataptr = dataptr;
+ pwriteMessage->message.count = count;
ellInit(&pwriteMessage->listenerPvtList);
epicsMutexMustLock(pasTrapWritePvt->lock);
ellAdd(&pasTrapWritePvt->writeMessageList,&pwriteMessage->node);
--- /opt/epicsB/base_old/src/rsrv/camessage.c 2007-09-24 13:59:25.992793308 -0400
+++ /opt/epicsB/base/src/rsrv/camessage.c 2007-09-24 13:45:17.414564490 -0400
@@ -791,7 +791,10 @@
asWritePvt = asTrapWriteBefore ( pciu->asClientPVT,
pciu->client->pUserName ? pciu->client->pUserName : "",
pciu->client->pHostName ? pciu->client->pHostName : "",
- (void *) &pciu->addr );
+ (void *) &pciu->addr,
+ mp->m_dataType,
+ pPayload,
+ mp->m_count);
dbStatus = db_put_field(
&pciu->addr,
@@ -1774,7 +1777,10 @@
pciu->asClientPVT,
+ mp->m_dataType,
+ pPayload,
+ mp->m_count);
dbPutNotify(&pciu->pPutNotify->dbPutNotify);
- RE: Patch: Enhancement to asTrapWrite? Jeff Hill
RE: DA property hierarchy for interfacing to the DBR_XXXX types Jeff Hill
Attention EPICS Core Developers! Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
