I am about to send out a series of patches (against R3.14.9) that DESY
have asked to be integrated into Base which are required to be able to
create redundant IOCs. The redundancy subsystem itself is a separate
module which redundant IOC applications must link to; these patches only
provide hooks into Base at appropriate locations.
We do not have to accept these changes as given, but I think it's
accepted that we want to make it possible for redundant IOCs to be
created without having to patch Base itself, so we'll have to suggest
some alternative technique to anything that we don't like.
I would appreciate comments and discussion from other developers on the
facilities being added and the proposed implementation. I am attaching
Gongfa Liu's description of the changes to this email, and I will send
out the changes in subsequent emails, grouped by subsystem. I will also
be commenting on the changes myself, in a separate message (probably
tomorrow).
Both Gongfa Liu and Bernd Schoeneburg who are responsible for this code
are subscribed to core-talk, thus they will see and can respond to all
comments sent here.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
Modified
# configuration
(1) for Linux, modify the related file in base/configure/os
OSITHREAD_USE_DEFAULT_STACK = YES
OP_SYS_CFLAGS += -rdynamic
OP_SYS_LDFLAGS += -export-dynamic
OP_SYS_LDLIBS += -ldl
(2) for darwin, modify the related file in base/configure/os
(3) for solaris, modify the related file in base/configure/os
# source files
(1) base-3.14.9/src/db/dbAccess.c
dbPutSpecial() is added for CCE. This function is just a pipe to
call the static function putSpecial(). dbPutSpecial() is written
by John L. Dalesio and Bernd Schoeneburg originally.
(2) base-3.14.9/src/db/dbScan.c
Register periodic scan tasks at RMT. When the IOC is SLAVE, these
tasks are changed to be inactive.
(3) base-3.14.9/src/dbStatic/dbBase.h
enum type "redUp" and the element of struct dbFldDes "red_update"
are added for CCE. They are added by Bernd Schoeneburg originally.
(4) base-3.14.9/src/dbStatic/dbLexRoutines.c
Deal with pdbFldDes->red_update for CCE, by Bernd Schoeneburg
originally.
(5) base-3.14.9/src/iocsh/iocsh.cpp
Change the definition of varArgs[2] in function
iocshRegisterVariable because there is compiling error with
tornado 2.2.1.This solution is from TRIUMF.
(6) base-3.14.9/src/libCom/osi/epicsMutex.cpp
The function epicsMutexLockWithTimeout() is added.
(7) base-3.14.9/src/libCom/osi/epicsMutex.h
The constant LOG_LAST_OWNER is defined. The function
epicsMutexLockWithTimeout and epicsMutexOsdLockWithTimeout are
declared.
(8) base-3.14.9/src/libCom/osi/epicsThread.h
The function epicsThreadDelete is declared.
(9) base-3.14.9/src/libCom/osi/epicsTime.h
The function epicsTimeGetTicks is declared.
(10) base-3.14.9/src/libCom/osi/os/posix/osdMutex.c
The structure epicsMutexOSD is extended and the function
epicsMutexOsdLockWithTimeout is implemented.
(11) base-3.14.9/src/libCom/osi/os/posix/osdThread.c
The function epicsThreadDelete is implemented.
(12) base-3.14.9/src/libCom/osi/os/posix/osdTime.cpp
The function epicsTimeGetTicks is implemented.
(13) base-3.14.9/src/libCom/osi/os/vxWorks/iocClock.c
(14) base-3.14.9/src/libCom/osi/os/vxWorks/osdMutex.c
The function epicsMutexOsdLockWithTimeout is implemented.
(15) base-3.14.9/src/libCom/osi/os/vxWorks/osdThread.c
(16) base-3.14.9/src/makeBaseApp/top/configure/RELEASE
The following lines are added for supporting iocRedundancy package:
#If using iocRedundacy package, point REDUNDANCY at its top directory:
#REDUNDANCY=$(EPICS_BASE)/../modules/soft/iocRedundancy
(17) base-3.14.9/src/makeBaseApp/top/exampleApp/src/Makefile
The following lines are added for building redundant IOC application:
# NOTE: To build redundant IOC application, REDUNDANCY must be defined
# in the <top>/configure/RELEASE file
ifneq ($(REDUNDANCY),)
_APPNAME__DBD += rmt.dbd
_APPNAME__DBD += cce.dbd
_APPNAME__DBD += snlexec.dbd
_APPNAME__LIBS += rmt
_APPNAME__LIBS += cce
_APPNAME__LIBS += snlexec
endif
(18) base-3.14.9/src/rsrv/camsgtask.c
Destroy client connenctions when the IOC is SLAVE.
(19) base-3.14.9/src/rsrv/caservertask.c
Register CAS-TCP task at RMT. Stop responding the client connection
request when the IOC is SLAVE.
(20) base-3.14.9/src/rsrv/cast_server.c
Inactivate CAS-UDP task when the IOC is SLAVE.
(21) base-3.14.9/src/rsrv/online_notify.c
Inactivate CAS-beacon task when the IOC is SLAVE.
Added
(1) base-3.14.9/src/db/rmtDrvIf.h
(2) base-3.14.9/src/rsrv/rmtDrvIf.h
The head file for RMT driver interface.
(3) base-3.14.9/src/libCom/osi/os/Linux/osdFindSymbol.c
Implement the function epicsFindSymbol for Linux.
(4) base-3.14.9/src/libCom/osi/os/posix/osdFindSymbol.c
Implement the function epicsFindSymbol for posix.
- Re: Redundancy Patches Eric Norum
Build rules for x86_64 hosts Denison, PN (Peter)
Redundancy Patch: configure Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
