Modified
# configuration
(1) for Linux, modify the related file in base/configure/os
OSITHREAD_USE_DEFAULT_STACK = YES
OP_SYS_CFLAGS += -rdynamic
OP_SYS_LDFLAGS += -export-dynamic
OP_SYS_LDLIBS += -ldl
(2) for darwin, modify the related file in base/configure/os
(3) for solaris, modify the related file in base/configure/os
Index: configure/os/CONFIG_SITE.darwin-x86.Common
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG_SITE.darwin-x86.Common,v
retrieving revision 1.1.2.1
diff -u -b -r1.1.2.1 CONFIG_SITE.darwin-x86.Common
--- configure/os/CONFIG_SITE.darwin-x86.Common 9 Nov 2006 14:47:56 -0000 1.1.2.1
+++ configure/os/CONFIG_SITE.darwin-x86.Common 14 Nov 2007 22:28:34 -0000
@@ -6,9 +6,12 @@
# Site override definitions for darwin-ppc host builds
-CROSS_COMPILER_TARGET_ARCHS = # RTEMS-uC5282 # RTEMS-mvme5500 RTEMS-mvme2100
+#CROSS_COMPILER_TARGET_ARCHS = # RTEMS-uC5282 # RTEMS-mvme5500 RTEMS-mvme2100
+#added by A.Kazakov
+OSITHREAD_USE_DEFAULT_STACK = YES
Index: configure/os/CONFIG_SITE.linux-x86.linux-x86
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG_SITE.linux-x86.linux-x86,v
retrieving revision 1.2
diff -u -b -r1.2 CONFIG_SITE.linux-x86.linux-x86
--- configure/os/CONFIG_SITE.linux-x86.linux-x86 15 Nov 2002 22:32:21 -0000 1.2
+++ configure/os/CONFIG_SITE.linux-x86.linux-x86 14 Nov 2007 22:28:34 -0000
@@ -5,7 +5,12 @@
# Site specific definitions for linux-x86 host - linux-x86 target builds
+OP_SYS_CFLAGS += -rdynamic
+OP_SYS_LDFLAGS += -export-dynamic
+OP_SYS_LDLIBS += -ldl
Index: configure/os/CONFIG_SITE.solaris-sparc.Common
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG_SITE.solaris-sparc.Common,v
retrieving revision 1.2.2.4
diff -u -b -r1.2.2.4 CONFIG_SITE.solaris-sparc.Common
--- configure/os/CONFIG_SITE.solaris-sparc.Common 1 Feb 2005 20:51:44 -0000 1.2.2.4
+++ configure/os/CONFIG_SITE.solaris-sparc.Common 14 Nov 2007 22:28:34 -0000
@@ -8,3 +8,6 @@
#INSTALL_LOCATION = /home/phoebus/JBA/testBaseNew
#CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc604 vxWorks-ppc603 vxWorks-68040
- Re: Redundancy Patch: configure Andrew Johnson
Redundancy Patches Andrew Johnson
Redundancy Patch: libCom Andrew Johnson
<2007>
2025
2026
epicsThreadDelete Re: Redundancy Patches Kay-Uwe Kasemir
<2007>
2025
2026
