Andrew Johnson wrote:
Modified
# configuration
(1) for Linux, modify the related file in base/configure/os
OSITHREAD_USE_DEFAULT_STACK = YES
Including the above change in Base will significantly increase the
stack size for most epicsThreads and severly reduce the number of IOCs
that a CA client such as the CA nameserver or PV Gateway can
simultaneously connect to, which is unacceptable. The reasoning is as
follows:
* Without the above change, each thread is explicitly given one of
three generically named stack sizes ('small', 'medium' or 'big').
The absolute size of these stacks can be configured by OS-specific
code, and for Posix-based systems like Linux the largest stack is
usually 512 KBytes.
* For Fedora Core 6 the default stack size is 10240 KBytes = 10 MBytes
(run 'limit' to find this value which may be different on different
Linux distributions). Even though the memory for a thread's stack
will be allocated sparsely, the OS enforces this spacing between
threads since it is not possible to move a stack after the thread
has started.
* On a 32-bit CPU, the User-mode memory space of any process can fill
at most half the 32-bit address space, i.e. 2 GBytes = 2048 MBytes.
* The CA client library creates 2 threads per TCP circuit, thus
requiring 20 MBytes of address space per IOC with the default stack
size but only 768 KBytes when variable sizes are allowed.
* A simple division shows that using the default stack size, no CA
client can connect to more than just over 100 IOCs simultaneously.
This is unacceptable since many sites now have more than this number
of IOCs and commonly need CA clients to be able to connect to a
majority of the site's IOCs.
If the EPICS stack sizes are too small for use with the RMT they can be
increased by changing a table in src/libCom/osi/os/posix/osdThread.c
instead of using the above setting.
OP_SYS_CFLAGS += -rdynamic
OP_SYS_LDFLAGS += -export-dynamic
OP_SYS_LDLIBS += -ldl
The above are provided to support epicsFindSymbol(), which is used in
the patched versions of src/db/dbScan.c and src/rsrv/caservertask.c to
look for the redundancy routine rmtRegister(). There are better ways
to do this; see my discussion on the other patches.
(2) for darwin, modify the related file in base/configure/os
See above argument about increasing thread stack sizes, although I
don't know what the defaults are on Darwin.
(3) for solaris, modify the related file in base/configure/os
See epicsFindSymbol() comment above.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Re: Redundancy Patch: configure Liu, Gongfa
- Redundancy Patch: configure Andrew Johnson
epicsThreadDelete Re: Redundancy Patches Kay-Uwe Kasemir
Re: Redundancy Patch: iocsh Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
