Andrew Johnson wrote:
Modified
# source files
(5) base-3.14.9/src/iocsh/iocsh.cpp
Change the definition of varArgs[2] in function
iocshRegisterVariable because there is compiling error with
tornado 2.2.1.This solution is from TRIUMF.
I was not aware of this problem, which I have never seen myself. I
assume that there is a newer version of the compiler available from Wind
River that I have installed here at APS which solves the issue, and as
a result I'm very reluctant to include this fix (which is not directly
related to the redundancy hooks that I'm discussing here).
Eric and I can't understand why this problem is not more widespread in
Base, since the same construct is used in many other places. If someone
else can demonstrate the problem and post the compiler error I will
reconsider.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Re: Redundancy Patch: iocsh Liu, Gongfa
- Redundancy Patch: iocsh Andrew Johnson
Re: Redundancy Patch: configure Andrew Johnson
Re: Redundancy Patch: db Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
