Modified
# source files
(5) base-3.14.9/src/iocsh/iocsh.cpp
Change the definition of varArgs[2] in function
iocshRegisterVariable because there is compiling error with
tornado 2.2.1.This solution is from TRIUMF.
I was not aware of this problem, which I have never seen myself. I
assume that there is a newer version of the compiler available from Wind
River that I have installed here at APS which solves the issue, and as
a result I'm very reluctant to include this fix (which is not directly
related to the redundancy hooks that I'm discussing here).
Eric and I can't understand why this problem is not more widespread in
Base, since the same construct is used in many other places. If someone
else can demonstrate the problem and post the compiler error I will
reconsider.
- Andrew
Hi, Andrew,
The following is the email copied from [email protected]. The
compiler error is same in our case. Maybe this compiler error can be
ignored here since it is not related to the redundancy patch.
> -----Original Message-----
> From: Graham Waters [mailto:[email protected]]
> Sent: Monday, January 05, 2004 5:52 PM
> To: [email protected]
> Subject: EPICS R3.14.4 for vxWorks-pentium
> Hi Folks
> I get the following compiler error while building R3.14.4 for a pentium
> target (vxWorks-pentium)
> Entering directory
> `/space/usr1/local/epics/release/R3.14.4/base/src/iocsh/O.vxWorks-
> pentium'
> /usr2/tornado/release/2.2.1/x86/host/sun4-solaris2/bin/ccpentium -c
> -D_POSIX_SOURCE -DCPU=PENTIUM -D_X86_ -DvxWorks -include
> /usr2/tornado/release/2.2.1/x86/target/h/vxWorks.h -ansi -O3 -Wall
> -mpentium -fno-defer-pop -x 'c++' -fno-implicit-templates
> -fno-builtin -I. -I.. -I../../../include/os/vxWorks -I../../../include
> -I/usr2/tornado/release/2.2.1/x86/target/h ../iocsh.cpp
> ..../iocsh.cpp: In function `void iocshRegisterVariable (const
> iocshVarDef
> ..../iocsh.cpp:133: Internal compiler error in `expand_expr', at
> expr.c:5996
> gmake[1]: *** [iocsh.o] Error 1
> This error does not occur for vxWorks-68040 or solaris-sparc-gnu targets
> I am using T2.2.1, gnu pentium cross-compiler v2.96 for solaris.
> Thanks
> Graham.
Bernd Schoeneburg and Gongfa Liu
Gongfa Liu MKS-2, DESY
phone: +49-40-8998-1642 Notkestr. 85
fax: +49-40-8998-4388 22607 Hamburg
e-mail: [email protected] Germany
- Re: Redundancy Patch: iocsh Andrew Johnson
- Redundancy Patch: iocsh Andrew Johnson
Re: Redundancy Patch: configure Liu, Gongfa
Re: Redundancy Patch: makeBaseApp Liu, Gongfa
<2007>
2025
2026
<2007>
2025
2026
