Ben Franksen wrote:
On Donnerstag, 29. Mai 2008, Andrew Johnson wrote:
Unfortunately if I commit these changes (which provide a comprehensive
solution) this will probably require *some* out-of-tree device and
record support changes to match, as in the above warnings from asyn
which are from pointers to the DBF_LONG state value fields (ZRVL etc) of
the MBB* record types.
It might be possible to reduce the impact of the fix while still getting
the IOC to work properly on 64-bit CPUs by not making DBF_LONG fields
become an epicsInt32 type. In this case, my current changes would move
to the main trunk for the R3.15 release.
Sorry for sidetracking but these sort of problems would barely exist if we
could decide on using a modern distributed version control system, like the
one we are now routinely using at BESSY, namely Darcs. Just set up an
experimental branch with full 64-bit compatibility. Everyone could
contribute fixes or add necessary changes as they find them. When the
branch stabilizes, merge the changes to the trunk and produce a new
release. Keeping the branch up-to-date w.r.t. changes on the trunk is easy,
fail-safe, and mostly automatic.(*)
The main disadvantage of CVS, Subversion, and other centralized VCSes is
that (1) every form of effective collaboration has to go through the
central repository and (2) merging changes from a branch to the main trunk
(or another branch) is tedious and error-prone.
This is especially a problem when facing the need to make invasive changes
that must be carried out uniformly in many different places unless the
product become unstable or buggy /and/ which cannot easily be carried out
by a single person.
There are many modern VCSes with characteristics similar to Darcs (mercurial
seems to be quite popular these days), however, we have had very good
experience with Darcs and since version 2.0 has been released, there is no
longer need to fear exponential blow-up on nested conflicts (if one uses
the new darcs-2 repository format, that is).
There are of course many more advantages in modern distributed VCSes
(specially over the outdated CVS) but I didn't want this message to grow
into a full-sized paper, so I'll just stop here. ;-)
Cheers
Ben
(*) The "mostly automatic" part depends to a certain extent on a reasonably
responsible and collaborative attitude of the developers, to help avoid
unnecessary conflicts. Specifically, changes should be recorded in small,
ideally localized, steps; larger redesigns or merely reformattings -- even
if limited to a subsystem -- should be carried out on separate branches
until stabilized, and communicated to other developers before merging, etc.
In our experience such behaviour is greatly encouraged by tools such as
Darcs, due to the simple fact that it (a) automatically decomposes your
changes into 'hunks' (blocks of changes on adjacent lines) and presents you
each such hunk separately for inclusion to a patch, and (b) that there is
the option of adding more changes to a patch after recording it. These
points make it extremely easy to separate changes into logically (but not
necessarily textually) connected groups for separate recording. A nice
side-effect is that patch descriptions tend to actually reflect what's been
done -- if you have the feeling it doesn't, there is a good chance you have
been mixing too many unrelated changes into your patch and should consider
re-recording in smaller steps (which is no problem at all if the patches
haven't been published yet). As a last point let me mention the possibility
to actually /try out/ whether (and where/why) conflicts appear w/o touching
the main repository.
Currently, we use CVS. There are some also so experimenting with
subversion as well.
However, should we take a serious look at Git?:
Git is distributed version control system focused on speed, effectivity
and real-world usability on large projects.
http://git.or.cz/
The linux kernel project uses Git.
Ernest
- Re: A modern DVCS would help Benjamin Franksen
- Fixes for 64-bit CPUs Andrew Johnson
- A modern DVCS would help (was: Fixes for 64-bit CPUs) Ben Franksen
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
