Benjamin Franksen wrote:
On Friday 30 May 2008 01:56, Ernest L. Williams Jr. wrote:
However, should we take a serious look at Git?:
One disadvantage is that it is poorly supported on Windows
(usability and efficiency-wise). I am not sure how critical this point is.
Critical, and as an aside git is apparently rather hard to learn.
My current intentions are to convert the existing monolithic CVS
repository into a series of Subversion repositories, split up by
project. We finally have the infrastructure set up here at APS to
support SVN+Trac properly.
*Before* anyone starts on about SVN not being a "modern distributed
version control system", take a look at the Bazaar VCS and its bzr-svn
plugin from http://bazaar-vcs.org/ which can transparently use SVN
repositories and working copies while managing local branches.
The reason I haven't moved forward with SVN yet is because there are
quite a number of CVS working copies around the world which this
switch-over will affect; I don't want anyone to lose uncommitted changes
or cause significant rework, so this switch will need coordination
between the core developers and should probably happen just after a release.
I'm also slightly nervous that our CVS repository, whose oldest log
messages date back to February 1991, will successfully convert to SVN.
The examples that I've tried so far have worked out fine, but they
didn't have branches. I'm guessing that we'll be fine, but that's not
proven yet.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: A modern DVCS would help Benjamin Franksen
- A modern DVCS would help (was: Fixes for 64-bit CPUs) Ben Franksen
- Re: A modern DVCS would help Ernest L. Williams Jr.
RE: Fixes for 64-bit CPUs Jeff Hill
<2008>
2025
2026
<2008>
2025
2026
