2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Redundancy in R3.14.10
Cc: [email protected], [email protected]
Date: Tue, 08 Jul 2008 09:16:12 +0200
Hi Andrew,
I am sorry not having understood everything last time. You did a lot of work again - examples also, thank you for that. The solution that you have implemented looks very nice to me, because I do not like conditional compilation as well. It took some time, but now I understood your new taskwd functions. taskwdMonitorAdd gives a maximum of flexibility for adding redundancy, error loggers, restarter and so on. Now there will be no redundancy-dedicated code in base, thats fine. The additional field attribute (copy to partner ioc: yes/no) is not implemented in this way. I have no good idea how to decide this without base modification. The interface between Epics and the RMT will be in a separate module, because RMT has no Epics calls inside.
Is it possible to control the ioc (redundancy status) by just using the top level functions iocPause and iocRun?
Bernd
Andrew Johnson wrote:
Hi Bernd,
On Thursday 03 July 2008 09:01:13 Schoeneburg, Bernd wrote:
I want to remind you that we are highly interested in base modifications
for IOC redundancy.
As I have said to you before, the next release *will* allow you to implement redundancy without modifying Base, although not using the patches that you developed.
The proposed model gives maximal freedom of usage.
-- If the define (REDUNDANCY) is not done, Episc runs as usual and no
additional object code is loaded.
I am less worried about adding a small amount of additional code than I am of getting the plug-in interface wrong. I do not like your conditional compilation solution because it makes the result hard to test (you have to completely rebuild Base with the conditional in the other state to be completely sure it compiles properly), and it requires me to ship a copy of your rmtDrvIf.h file with Base (which makes it hard for you to make any changes to that file).
I am attaching a file which should become part of the Redundancy Monitor and hooks into the interfaces I am providing. You won't be able to use this yet because I haven't committed the parallel changes that are needed to Base, but it shows you that it will be possible to make an IOC redundant without adding more code to Base. This source code compiles without errors on my system, although it won't link because I don't have the rmtRegister() routine or the rest of the RMT subsystem. It is likely that you'll have to make some changes, but I think the majority of this code is correct.
I accept that you need to be able to control some of the internal threads inside the IOC, and as a result I am adding a series of 'xxxPause()' and 'xxxRun()' routines to the various internal subsystems, as well as adding top level 'iocBuild', 'iocPause' and 'iocRun' commands (in a redundant IOC you will use 'iocBuild' instead of 'iocInit' in the startup script, ensuring that the server and scan tasks are not started). While doing that I have also been cleaning up the startup and shutdown procedure for the IOC, so there is some advantage in this work for others as well.
After some more tests early next week, I will be committing my changes to CVS and you'll be able to try them out.
- Andrew
Re: IOC Redundancy in R3.14.10 Andrew Johnson
IOC Redundancy in R3.14.10 Schoeneburg, Bernd
Prev: Re: IOC Redundancy in R3.14.10 Andrew Johnson
Next: Re: IOC Redundancy in R3.14.10 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
