2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Redundancy in R3.14.10
To: Bernd Schoeneburg <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 8 Jul 2008 15:39:41 -0500
Hi Bernd,
On Tuesday 08 July 2008 02:16:12 Bernd Schoeneburg wrote:
> The additional field attribute (copy to partner ioc: yes/no) is not
> implemented in this way. I have no good idea how to decide this without
> base modification.
The last time we talked about that you hadn't actually set that attribute on
any of the base record types, so I wasn't sure whether you still need it or
not.  I don't think it would be too hard to provide the attribute information
to the CCE outside of the original DBD file, although admittedly it might
complicate the code a bit.
At start-up the CCE would read one or more configuration files listing the
record type field names of all the non-default fields and saying what their
redundancy attribute setting should be.  Later the CCE code will have to do a
parallel look-up in this structure to find that attribute value when it needs
it, but it might be possible to reduce the workload by combining this
information into some other data structures — that's hard to guess without
seeing the code for the CCE though.
> Is it possible to control the ioc (redundancy status) by just using the
> top level functions iocPause and iocRun?
Yes; if you don't need control over the individual tasks then you can use
those calls instead, and that would simplify some of my changes.  I suspect
Jeff would much prefer that we provide only rsrv_pause() and rsrv_run() than
to make the individual server subsystems visible in the way I currently do.
I wasn't sure whether that would be Ok or not for the RMT since you then
wouldn't have a 1:1 mapping between server tasks and start/stop routines, but
I'm happy to take the extra routines out of rsrv if you don't need them.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: IOC Redundancy in R3.14.10 Ben Franksen
Re: IOC Redundancy in R3.14.10 Schoeneburg, Bernd
Re: IOC Redundancy in R3.14.10 Andrew Johnson
Re: IOC Redundancy in R3.14.10 Bernd Schoeneburg
Prev: Re: IOC Redundancy in R3.14.10 Bernd Schoeneburg
Next: Re: IOC Redundancy in R3.14.10 Ben Franksen
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
