Hi Andrew,
Andrew Johnson wrote:
The last time we talked about that you hadn't actually set that attribute on
any of the base record types, so I wasn't sure whether you still need it or
not. I don't think it would be too hard to provide the attribute information
to the CCE outside of the original DBD file, although admittedly it might
complicate the code a bit. ...
Up to now we have not so very big databases and the ioc hardware is fast
enough. So we could live without that at all. But if we need it one day
we won't like it very much to have a second set of "dbd's". So for now
we should (temporary) forget it and keep it in mind.
... if you don't need control over the individual tasks then you can use
those calls instead, and that would simplify some of my changes. I suspect
Jeff would much prefer that we provide only rsrv_pause() and rsrv_run() than
to make the individual server subsystems visible in the way I currently do.
I wasn't sure whether that would be Ok or not for the RMT since you then
wouldn't have a 1:1 mapping between server tasks and start/stop routines, but
I'm happy to take the extra routines out of rsrv if you don't need them.
The RMT starts and stops all registered tasks without looking what kind
they are. We could in principle understand the whole base tasks as one.
The Epics task watchdog does the supervision already. When we subscribe
for a change of state (suspended) then a single combined state could be
offered to the RMT. Detailed information could be made available to the
RMT by the RMT get_info methode.
In other words rsrv_pause and rsrv_run would be sufficient. Other
individual subsystem controls would be nice but not absolutely
necessary. If iocPause and iocRun stops/starts the individual tasks in
the right order it would be better than we can do with the RMT.
Bernd
- IOC Redundancy in R3.14.10 Schoeneburg, Bernd
- Re: IOC Redundancy in R3.14.10 Andrew Johnson
- Re: IOC Redundancy in R3.14.10 Bernd Schoeneburg
Re: IOC Redundancy in R3.14.10 Ben Franksen
<2008>
2025
2026
Re: IOC Redundancy in R3.14.10 Benjamin Franksen
Re: IOC Redundancy in R3.14.10 Artem Kazakov
<2008>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
