2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base's support on Phar Lap ETS
To: [email protected]
Cc: [email protected]
Date: Tue, 19 Aug 2008 11:34:18 -0500
Hi Alex,
On Monday 18 August 2008 04:50:47 [email protected] wrote:
>     We're trying to migrate EPICS Base to Phar Lap ETS ( a real-time
> operating system from Ardence ) these days, and it turns out the modified
> Base works well on Phar Lap. Phar Lap's system API is much like the WIN32
> API, with the differences as follows:
> 1. Thread Priority Range is (-128 to 127), much like VxWorks' (0 to 256)
> 2. You cannot create a process, only one process allowed on PharLap
> 3. Only WinSock 1.1 is supported on Phar Lap
> 4. Other minor issues...
>     What I want say is can we make some contribution to the EPICS Base,
> let the libCom support a new realtime OS Phar Lap ETS? Any suggestions
> from you guys are appreciated :-)
Jeff has already talked about some technical aspects of the port, which is
expected to provide a couple of new files in configure/os and a new directory
with files in it under libCom/osi/os.  If you need to make any changes to
code elsewhere in the tree they will need to be examined closely; we are
trying hard to eliminate all architecture-specific code elsewhere, so #ifdef
blocks are not generally accepted.
I would also advise you that there have been a number of changes since R3.14.9
was released some of which may affect your port; your code is too late to be
included in R3.14.10 which I would like to get released within the next month
or so, but after that release I'd be happy to see you work with Jeff to get
the code incorporated and with Janet Anderson on the configuration files.
In the meantime, before we can accept any code we have to get the legal side
in place, which will involve your management or legal department signing a
Grant of License to give Argonne the right to distribute and modify your
code.  Please visit http://www.aps.anl.gov/epics/license/grant.php which
shows the text of the Grant that our legal department prefers.  When you're
ready, fill in the form with the name of whoever will be authorized to sign
it on behalf of NI; submitting the form does not store any information on our
webserver, it just generates a document suitable for printing out.  Please
print it, have it signed and then fax it to me at +1 (630) 252-6123
- Andrew Johnson
Talk is cheap. Show me the code. -- Linus Torvalds
EPICS Base's support on Phar Lap ETS Alex . Chen
Prev: RE: EPICS Base's support on Phar Lap ETS Jeff Hill
Next: Re: IOC Redundancy in R3.14.10 Artem Kazakov
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Base R3.14.10-pre1 available for testing Andrew Johnson
