2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness
To: [email protected]
Cc: "Ernest L. Williams Jr." <[email protected]>
Date: Wed, 17 Sep 2008 09:54:01 -0500
Hi Ernest,
On Wednesday 17 September 2008 00:01:58 Ernest L. Williams Jr. wrote:
> Target:  MVME3100
> OS: vxWorks 6.6
> EPICS: base-R3-14-10-pre1
> Looks like, I failed on an exception.
The libCom tests are meant to be a standalone program run in a system without
an IOC running.  Please boot vxWorks with no startup script, load *only* the
vxTestHarness.munch file and then execute epicsRunLibComTests — if everything
passes you should only need to post the overall summary message printed at
the end (at which point you'll have to Ctrl-C to get a shell back).  RTEMS is
going to be similar using rtemsTestHarness.elf, although I'm not sure if we
build it properly for the CEXP configuration — Eric?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Eric Norum
vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
Prev: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
Next: Re: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Eric Norum
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
